Results 1 to 8 of 8
Thread: Misfire! Bad coil packs and spark plugs.
    TG Platinum VIP
    NEW MEXICOS BEST's Avatar
    12-08-10
    ALB, NEW MEXICO
    1,785
    $55182
    44
    Default Misfire! Bad coil packs and spark plugs.
    Good morning all, SC tundra was not running well at all so I sent it in for Srv and after diagnostic the coils were bad on two cylinders and the plugs bad also. They wanted $2700 to fix so I just brought my baby home and I will fix it myself. Is there anything I should know before I tackle this project? Thanks
    TRD SUPERCHARGER
    TRD DUAL EXHAUST
    TRD Sway bar custom powdercoat blue
    PRO COMP 3/1 LEVEL KIT
    PRO COMP 305/60/18 TIRES
    KMC HOSS 18 IN WHEELS
    CUSTOM TRD INLAY IN CENTER OF WHEELS
    COLOR MATCHED BREAK CALIPERS
    OEM NAVIGATION
    BACK UP CAMERA,AND BACK UP SENSERS
    AFTERMARKET REAR ENTERTAINMENT CENTER
    TECH12VOLT SUB BOX
    2 10IN KENWOOD SHALLOW SUBS
    KENWOOD 1000W AMP
    G TEK FAB SABM KIT
    AND MANY MORE TO COME
    4,358
    85
    Default Re: Misfire! Bad coil packs and spark plugs.
    Hey..long time no see!!
    $2700 for coil packs and plugs? Change the bad coil packs and all the plugs. People will tell you to change all the coil packs, but I would just change the bad ones. It is easy to diagnose a bad coil pack. Just switch it with another and see which cylinder is throwing the codes. Don't forget to blow out the holes before you remove the plugs. Let us know how you make out.
  3. Thanks NEW MEXICOS BEST "Thanks for this post"
    831
    24
    2700??? I hope that's for chocolate kisses, and not actual money... I was quoted that much for a starter, last year...
    TG Platinum VIP
    12-08-10
    ALB, NEW MEXICO
    1,785
    $55182
    44
    Hahaha I wish! That’s why I drove it home and ordered all the parts. $500 total and I will be doing work tomorrow
    TRD SUPERCHARGER
    TRD DUAL EXHAUST
    OEM NAVIGATION
    TECH12VOLT SUB BOX
    KENWOOD 1000W AMP
    G TEK FAB SABM KIT
    831
    24
    LOL, That reminds me of a day I took my Celica in for a brake job, and they were like 4,99,99 per axle. The way they said it threw me off, so I asked 49.99? And was corrected swiftly, 499.99... so I further inquire just to make sure I was listening correctly and didn't become deaf all of a sudden, and stated for all 4 corners, and was corrected one more time with NO. 500 for front, 500 for rear, and I was like, but all I need is a resurface and new front pads? no more than $100 total, since rears were drums. So he states, its what the service entails, so I swiftly replied, do I drive through, or I back up... I did it myself, less than $100, inspected my drums and drenched them in brake klean, resurfaced the rotors at Pep Boys for $8 each, yes 8 dollars... most expensive were the brake pads were about $70 for the time, still dusted the **** out of my rims though.....
    TG Platinum VIP
    12-08-10
    ALB, NEW MEXICO
    1,785
    $55182
    44
    What’s up TG fam! Follow up on the SC beast misfire issue. So on Friday I removed all 8 coil packs and removed the spark plugs. 3 out of 8 plugs were completely worn down with no iridium point left on the plug. The other 5 looked good. These plugs are the original plugs I installed with the SC about 48,000 miles ago. Reading about the gaps on the plugs I knew they needed to be at 44 on the plug gap on the coin thing. I measured the ones I took out and they were all around 30. Looks like the Toyota dealership never gaped them on install. I replaced all 8 coil packs just to get a fresh start even though I know I didn’t have to but that’s how I am. So $452 later it is running perfect with a lower idle RPM. Can’t even hear it now but when I get on the gas the SC wakes up and runs smooth. Thanks for the advice and I recommend and encourage you guys to try it yourself. I saved about $2200 from what the shop wanted to charge me.
    TRD SUPERCHARGER
    TRD DUAL EXHAUST
    OEM NAVIGATION
    TECH12VOLT SUB BOX
    KENWOOD 1000W AMP
    G TEK FAB SABM KIT
    4,358
    85
    Glad to hear that!!
    831
    24
    Awesome to hear
