Results 1 to 10 of 10
Thread: Please Help with 2012 Tundra fog lights!!!
    02-03-14
    17
    $5540
    Default Please Help with 2012 Tundra fog lights!!!
    I recently purchased a "OEM" fog light kit from WinJet. The install was easy and looks very nice, however I cant get them to work with the switch. I am using the factory wiring on the truck, and I installed a relay in the fuse box. I checked the switch and it appears to be good, when checking for continuity it's there between the Red wire and the Black (Grnd) wire. So in theory it should work because if I jump out the blue wire from the harness to ground the lights come on, when i plug the harness into the switch they will not work but as I stated earlier i can check the switch through the switch through the harness and i do get continuity. My harness also has a yellow wire, and if i connect it to the green wire (3rd one down) the led's on the switch stay illuminated. I attached a pic of what my switch looks like I hope it is actually attached and helps.
    Thanks for your help in advance!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    4,211
    80
    Default Re: Please Help with 2012 Tundra fog lights!!!
    That is a tuff one to diagnose with out being at the truck. Where are you located?
    02-03-14
    17
    $5540
    West Virginia
    4,211
    80
    Pretty far from Long Island. You received the factory stalk switch with the kit?
    02-03-14
    17
    $5540
    Quote Originally Posted by tonyspin View Post
    Yes it did include a switch. I dont know if it is stock, it looks stock. It mount in a blank on the dash to the left of the steering wheel.
    02-03-14
    17
    $5540
    I have seen where other people have used a similar switch, it has a red, blue, and ground wire. My switch harness looks just like that one. Is there a way for me to get the pinout of that harness, so I can see what wires are actually being used. Mine has 4 wires coming from the green harnesss but the 2 red are tied together.
    4,211
    80
    The stock switch is on the turn signal stalk. You are using an after market switch. This is an easy problem to solve. Maybe you have a friend that can check it for you.
    02-03-14
    17
    $5540
    Unfortunately I don't
    02-03-14
    17
    $5540
  10. #10
    08-14-18
    I just purchased a 2011 Tundra, installing fog lights, truck is pre wired and I'm having the same wiring the switch issue. Did you get them straightened out to work with your switch? I have the same one and just the switch lights up. how did you or anyone wire it if you got it to work?
  1. 1st gen Tundra lights
    By tundrajonny in forum Headlights/Tail Lights/Third Brake Lights/HID & LED's
    Last Post: 03-29-2015, 08:18 AM
  2. [Modification] Toyota tundra HID reverse lights done
    By i20rider in forum 2000/2006 DIY Guides & Mods
    Last Post: 09-11-2011, 07:25 PM
