Below Header GoPro
Thanks Thanks:  5
Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: FREE 2014 Toyota Tundra fog light Mod.
    Seasoned Veteran
    cater's Avatar
    08-19-09
    Little rock, Arkansas
    2,256
    $6475
    42
    Default FREE 2014 Toyota Tundra fog light Mod.
    This modification is based on the 07-13 Tundra Fog light mod, But things are not exactly the same. This is a basic overview of the process. I do not have connector names or numbers for the 2014 as I do not have any wiring diagrams for this vehicle. I had to find the correct wire's via the old school method of a multimeter. If there is anything you need more information on just hit me up. I should be able to do a detailed write up as soon as I get a wiring diagram.
    This mod is just a basic jumper wire, You can do this mod on your lunch break, Simple and straight forward.
    New functions:
    1. Fog lights ON while parking lot lights ON
    2. Fog lights on while High beam ON
    In spite of these new functions, The Auto ON/OFF, delay timers and FOB control operation remains intact. Headlamp timer vehicle customization via entune is still available.
    It's advised to disconnect negative terminal on battery and unplug the connectors before doing this mod.
    Tools: 10mm, Wire cutters, Wire strippers, 5 1/4" female fully insulated crimp on connectors. (red 18ga), 3 Fully insulated male crimp on connectors (RED). 1' of 18-22ga Wire.
    1. Remove the Driver side Door seam panel and the kick panel. Next remove the Panel underneath the steering column, This panel has two 10mm bolts after those are removed it just snaps off the same as the door seam panel and kick panel.
    2. Locate this connector on main body ECU. It's the white connector second from the top. On this connector in pin location #28 (Bottom row) is a pink wire. Cut it about 2" from the connector. On the connector side crimp on a 1/4 female connector. On the harness side crimp on the male connector.
    3. Move on to the kick panel, Remove grey connector pictured below.
    This connector contains TWO GREY WIRES! The grey wire on the TOP LEFT 3rd Row is the one you want. Snip it 2" above the connector and crimp a female crimp on the connector side and a male on the harness side.
    4. Get your 1' of 18-22ga wire and crimp on a female connector on each side. Now connect the Pink and Grey wires together via the jumper wire.
    Now TEST operation and reinstall removed parts.
    The first TRD Supercharged 2009 Tundra.. you can View My modification's and Pictures in the T.G garage, Just follow the Link:
    http://tundrageeks.com/forum/garage_..._vehicle&id=52
    click link below. Its a contest for me..
    2009 Toyota Tundra SR5: 12.739 @ 108.680 MPH
  2. Thanks Supercharged, JPNCA, Bowhunterman, paulskie "Thanks for this post"
  3. #2
    25,245
    364
    Default Re: FREE 2014 Toyota Tundra fog light Mod.
    Awesome!
    You're the king of 3rd gen mod threads so far cater.
    48
    Awesome work Cater!!!
    11,985
    184
    Nice
    Good job
    11 Second Tundra! Supercharged's Avatar
    09-06-11
    Coconut Creek. Florida
    1,133
    $35115
    28
    Truck's looking great.
    TRD Supercharger, Shift Kit, M&H Cheater Slicks, Rear Cat Delete, Ground Force 3" lowering rear leaf, G-Tek Airbox Mod, Magnaflow 12468 DI/DO with turndowns, Caltrac Traction Bars, 2400 rpm TC, ASP Bigger Crank pulley, ASP water pulley, Trick Performance 2 gallon reservoir, Killer Chiller, AEM wideband, Autometer water (intercooler fluid) temp gauge, Craven Speed Dual Gauge Pod, AIS water/Meth Injection, ASP supercharger pulley, Ultra Gauge.
    First 11 Second Tundra. 11.940 @ 113.19mph.
    1.66 second 60'.
    Track Video. First 11 Second Tundra!! http://www.youtube.com/watch?v=Bb9MNYFwUFA
    Track Video 12.034 @ 113mph http://www.jdmtube.com/video/657/Toy...PH-PBIR-Moroso
    Track Video 12.15 http://www.youtube.com/watch?v=gr09O...e_gdata_player
    Novice
    07-04-12
    156
    $6240
    8
    Thanks light mod done on are 14 cm
    Novice
    07-04-12
    156
    $6240
    8
    Only problem wife want this mod done
    To her celica,and mustang ?? Think you can
    Do the home work on those for me ? Lol
    02-19-13
    $5710
    Thank you so much for the walk through! Just finished the mod on my 2014 CM and it worked flawlessly! You da man!
  10. #9
    Seasoned Veteran
    cater's Avatar
    08-19-09
    2,256
    $6475
    42
    Glad this mod is going easy for you guys!
    Welcome to TG Bowhunterman
  11. #10
    10-14-14
    Quote Originally Posted by cater View Post
    Just curious, do you just leave the other two connectors not connected to anything?
  12. #11
    paulskie's Avatar
    10-05-14
    Auburn, WA
    40
    Thanks for the great post
    2014 Black Metallic 1794
    TRD Sway, G-Tek AirBox Mod, Linex, Interior LED Mod.
  13. #12
    Seasoned Veteran
    cater's Avatar
    08-19-09
    2,256
    $6475
    42
    Quote Originally Posted by fat2na View Post
    Been a while, but I think everything is connected.
  1. Review of 2014 Tundra (and 4Runner) In Feb 2014 Issue of Off Road Magazine
    By brightdim1985 in forum 2014+ Toyota Tundra/3rd Generation Discussion
    Last Post: 03-06-2014, 08:29 AM
  2. FREE 2014 How To Debadge (Cater Style)
    By cater in forum 2014+ DIY Guides and Mods
    Last Post: 12-29-2013, 07:59 PM
  3. 2012 Toyota Tundra Review Chattanooga Times Free Press
    Last Post: 09-04-2012, 07:52 AM
  4. Toyota Gives Kids Against Hunger a Free Tundra
    Last Post: 02-29-2012, 04:51 AM
