Shop at 4WheelParts.com and get FREE SHIPPING and 100% Price Matc
Thanks Thanks:  2
Thread: FREE 2014 How To Debadge (Cater Style)
    Seasoned Veteran
    cater's Avatar
    08-19-09
    Little rock, Arkansas
    2,256
    $6475
    42
    tools FREE 2014 How To Debadge (Cater Style)
    This should be about the same as all other debadge but here is My take on it. I prefer to use a hair dryer over a heat gun
    as it heats at a much safer temperature.
    Tool's.
    Hair dryer
    monofilament AKA Fishing line
    Isopropyl Alcohol
    Rag
    Spray wax (optional)
    Step one: Heat badge with hair dryer on high setting for 1-2 Minutes.
    Step two: grab your "Fishing Line" and in a sawing motion and pulling slightly towards the badge "Cut" the Adhesive tape from the badge.
    pulling towards the badge will ensure that you don't get into the paint. The elongated "Tundra" badge is a little more easy if you heat 3 letters at a time.
    Step three: After cutting the adhesive, Pull the badge off from the bottom corner to the opposite corner.
    Step four: Remove the remaining adhesive by rolling it off via your fingers.
    Step five: Wipe off any excess residue using your handy rag and isopropyl alcohol.
    Before:
    After:
    The first TRD Supercharged 2009 Tundra.. you can View My modification's and Pictures in the T.G garage, Just follow the Link:
    http://tundrageeks.com/forum/garage_..._vehicle&id=52
    click link below. Its a contest for me..
    2009 Toyota Tundra SR5: 12.739 @ 108.680 MPH
  2. Thanks jbroas "Thanks for this post"
  3. #2
    48
    Default Re: FREE 2014 How To Debadge (Cater Style)
    You forgot the one on the tailgate...
    Sorry, I had to.
  4. Thanks jbroas "Thanks for this post"
  5. #3
    Seasoned Veteran
    cater's Avatar
    08-19-09
    2,256
    $6475
    42
    Quote Originally Posted by MPToy07 View Post
    Sorry, I had to.
    Yeh, Body filler is later down the road.
  1. [Build Log] Cater's 09 Tundra Build Log
    By cater in forum 2007/2013 Tundra Build Logs
    Last Post: 03-03-2012, 10:13 AM
  2. Vote for cater!
    By Dez in forum IF5.7 General Discussion & Help
    Last Post: 06-01-2011, 05:13 PM
