Thanks Thanks:  7
Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 42
Thread: 07 Tundra Engine Codes p0171 and p0174 Need Help
  1. #13
    50
    Default Re: 07 Tundra Engine Codes p0171 and p0174 Need Help
    Hey Henry!!!
    Sorry I haven't chimed in till now, I've been busy with the holidays.
    So P0171, and P0174. Those are very common codes.
    First questions; What year truck? Engine? S/C or N/A?
    There are many things that can cause this code. Because you've already replaced the MAF, that can be ruled out.
    Next question; does your code reader also have the ability to display data lists? If so, go into the data list and watch Short term and Long term fuel trim. Long term is an adpated number that changes over a period of time. Short term is instant. Both of those numbers should be as close to zero as possible at all times. If the numbers are positive, it means the computer sees the truck is running lean, so it adds fuel. Negative numbers are the exact opposite. Your numbers will obviously be positive. So here's what you do;
    1) See what the numbers do while idling. My guess is that they will both be higher than 15.
    2) Take the truck for a drive, and see what the numbers do then (preferably with a passenger to monitor while you drive). You will need a decent refresh rate on your code reader for this also. If the numbers stay high when accelerating, then it is most likely a sensor issue, or possibly fuel pressure. My guess is that while accelerating, the numbers will go down closer to zero, then climb back up when idling or cruising, which means you have a vacuum leak somewhere. I know you said you smoke tested the truck, but there's so many things connected to the intake that you may not even see where the smoke is going.
    3) If step 2 determines there is a vacuum leak, keep the truck running, and the code reader connected with long and short term fuel trim up on the screen. Now, find all components that run off engine vacuum (brake booster, EVAP system, etc.), and disconnect them one at a time, plugging the vacuum port to the engine. What this does is eliminates that component from the system. When you find the faulty component, you will know it. THe Long term fuel trim will stay positive, but short term fuel trim will go negative about the same amount. Leave each component disconnected for about 5 minutes before hooking it back up, to see if the numbers change. Also, look at the crankcase vent tubes, to see if they are still hooked into the air intake tube. Those being disconnected can cause the light to come on also.
    Good luck, post any questions here, or let us know what you find!!!
  2. Thanks Dez, 07TRD, cater, tonyspin "Thanks for this post"
  3. #14
    07TRD's Avatar
    01-13-13
    46
    $6235
    Thank you for the Reply I will try this today when the shop slows down, We have a Snap On Scanner ( the most updated newest one) so I'm sure it has all that data stuff I'll let you know what I find, The Truck is a 07 with 119,000 Miles, I Love the Truck but the problems I've had this year is burning a hole in my pocket
  4. #15
    25,363
    367
    I'm thinking vacuum leak.
  5. #16
    50
    Good luck man!!!
  6. #17
    07TRD's Avatar
    01-13-13
    46
    $6235
    Heres what I have at Idle
    Short FT #1 -0.03 +0.75
    Long FT #1 25.74
    Short FT #2 7.78 - 8.56
    02 FT B2 S2 99.2
    AF FT B1S2 0.993-1.001
  7. #18
    50
    ok, so the Long term fuel trim on bank 1 is showing the engine is for sure running lean. I don't see Long term for bank 2 on there, but I am guessing it's somewhere near the same as #1.
    Now take it for a drive and watch those numbers as you accelerate. If long tern #1 and #2 goes down when accelerating, that means you FOR SURE have a vacuum leak at idle, and you'll need to follow the instructions above to figure out where it's coming from.
    Most of the time, it's the larger of the two additional hoses connected to the intake tube that's left off. I did, however, have a couple cases where the brake booster developed a leak, and was constantly allowing air to be sucked in, leaning out the engine. That's very rare though. Another thing I've seen is the EVAP purge valve being stuck open, but you would usually get an EVAP code popping up if that was the case. The final thing I've seen is the tube for the PCV system being disconnected (I left one off once by mistake after replacing the air pumps), but I'm guessing you would've seen that with your smoke test.
    Let us know what you find.
  8. #19
    4,275
    If it started right after the alternator replacement, check for a vacuum line that was left off during the installation. Maybe one is just not pushed on all the way.
  9. #20
    07TRD's Avatar
    01-13-13
    46
    $6235
    I Checked all the Hoses Moved everything wiggled everything and I Drove around and the Light hasn't come back on yet, My MPG seems like it is improving a little on the display, I'll give it a week and see how it goes.
  10. Thanks Dez "Thanks for this post"
  11. #21
    25,363
    367
    Lol! You wiggled your hose...
  12. #22
    4,275
    Quote Originally Posted by Dez View Post
    Pictures?
  13. #23
    07TRD's Avatar
    01-13-13
    46
    $6235
    lol i'll get a video, I know you all like videos, anyways i'll definetly check in the forum more I missed all you guys and all your helpful hints. Thanks a lot i'll keep you all posted on whats going on
  14. Thanks Dez "Thanks for this post"
  15. #24
    07TRD's Avatar
    01-13-13
    46
    $6235
    problem came back, getting 9 mpg city and 12-13 highway My boss will look at the suggestion by mptoy today and help me look into it, I have an appointment with Toyota tmrw to check out a 2014 Tundra The only code I got was p0174
  1. Four Cylinder Engine Production Begins At Toyota's Alabama Engine Plant
    Last Post: 09-29-2011, 07:42 AM
  2. 1st Gen Tundra Engine & Chassis Codes
    By Dez in forum 2000/2006 Tundra Maintenance/Repair/Specs/Warranty Discussion
    Last Post: 08-07-2010, 04:22 PM
  3. Scangauge X-Gauge Codes For Tundra
    By tonyspin in forum Questions/Help/Schematics
    Last Post: 08-07-2010, 12:26 AM
