Thanks Thanks:  3
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Power loss between first and second gear.
  1. #13
    4,171
    78
    Default Re: Power loss between first and second gear.
    Quote Originally Posted by Blown5.7 View Post
    I've read about this before on newer trucks after a cold air kit was installed with exhaust. I agree, holding down the VSC or LSD button for 3 sec's would work - but i'm curious if holding down the button AGAIN for another 3 secs to disable everything would be better. My '12 allows me to do that. No Nannies. Not sure if the newer trucks allow for that.
    For 2007 trucks, 2 presses of the button turns of everything. On 2008 and newer trucks, 3 presses turns off everything. Truck must be stopped. 2nd and 3rd press must be held for 3 seconds. First press can be momentary.
  2. #14
    Rookie Texican's Avatar
    03-22-16
    1
    2014 5.7L
    I've noticed that delay or little catch right there around 1st and 2nd. Holding down the traction control button until both autoLSD & VSC lights come on will free up the throttle some, but if the tires break loose the TRAC will kick in reducing engine output automatically. However, with both autoLSD & VSC lit up, if you activate 4-HI then switch back to 2WD you will turn TRACTION CONTROL OFF and will have no electronic restrictions on your throttle. I hope this info might be of some use.
    Sent from my iPhone using Tapatalk
  1. 4.30 Gear Swap
    By MPToy07 in forum IF57 Race Group
    Last Post: 05-06-2013, 08:46 PM
  2. Ford F-150 EcoBoost Problems: Shuddering, Power Loss & Limp Mode
    Last Post: 10-19-2012, 01:17 PM
  3. BlackHawk gear! Get it while you can!
    By 5.7yotafan in forum Wepons/Self Defence
    Last Post: 10-13-2012, 08:38 PM
  4. Power Seat Problems? Toyota Tundra Power Seat TSB
    Last Post: 07-20-2011, 08:32 PM
