Thanks Thanks:  2
Results 1 to 9 of 9
Thread: Recall on driverside electric windows
    Rookie tundra2007's Avatar
    08-16-13
    7
    $5790
    Default Recall on driverside electric windows
    Just received letter on my 2007 tundra about recall on electric door panel switches for windows causing fire.
    Anyone else get a letter on this?
    Sent from my MB865 using Tapatalk 2
    Seasoned Veteran
    Rut's Avatar
    PA
    3,757
    $64396
    69
    Default Re: Recall on driverside electric windows
    Nope, not yet
    25,363
    367
    I got it last month. No fires yet either.
    TG Platinum VIP
    NEW MEXICOS BEST's Avatar
    12-08-10
    ALB, NEW MEXICO
    1,781
    $55182
    42
    When I got oil changed a few weeks ago they went in and made repairs on switch
    TRD SUPERCHARGER
    TRD DUAL EXHAUST
    TRD Sway bar custom powdercoat blue
    PRO COMP 3/1 LEVEL KIT
    PRO COMP 305/60/18 TIRES
    KMC HOSS 18 IN WHEELS
    CUSTOM TRD INLAY IN CENTER OF WHEELS
    COLOR MATCHED BREAK CALIPERS
    OEM NAVIGATION
    BACK UP CAMERA,AND BACK UP SENSERS
    AFTERMARKET REAR ENTERTAINMENT CENTER
    TECH12VOLT SUB BOX
    2 10IN KENWOOD SHALLOW SUBS
    KENWOOD 1000W AMP
    G TEK FAB SABM KIT
    AND MANY MORE TO COME
    RedBullistic's Avatar
    06-06-13
    Wa. State
    97
    $6450
    8
    I recieved mine and had the work done in Febuary 2013.. Simple fix
    50
    Yep. The dealer removes the switch and inspects for any sign of excessive resistance or burnt contacts. If neither of these is present, additional grease is applied to the switch to prevent it from sticking or wearing abnormally. If there's any suspected issues, the circuit board is replaced. Simple fix for a potentially serious issue. Get it done!!!
  7. Thanks Dez "Thanks for this post"
    25,363
    367
    Quote Originally Posted by MPToy07 View Post
    Great info Mike! That could possibly be a simple thing for any DIY'er to do.
    Novice jbroas's Avatar
    03-12-10
    San Diego, CA
    272
    $23555
    14
    Has there been any news of any door switch fires? I'll have to wait until I eek out of the last stretch of my powertrain warrentee (April 2014). My crazy "warantee voiding mods" are too much to "take off and hide" in case they document "what they see"..-LOL
    Performance Mods:
    Precision 78mm TURBO on a 4lb WG spring -using Stock ECU, AFR is rich at 10.0:1
    Dynojet -400rwhp 472 tq
    Valve Body Shift Kit
    2800 High Stall Torque Converter
    Doug Thorley Headers
    Caltracs Traction Bars
    Auburn Pro LSD
    30" MH Cheater Slicks on 16"x10" ProComp Wheels! (Track Use)
    Turbo Back>3"CutOut>CAT>26" "BIG BERTHA" BAmuffler!
    Electric Fan Conversion (DirtyDeeds BamFan)
    TundraRacing 2/4 Lowering Kit
    AEM Tuning = Next Mod
  10. #9
    50
    Quote Originally Posted by Dez View Post
    Toyota actually states that the DIY person is what is causing the fires, due to using an incorrect lubricant on the switch. The "grease" Toyota supplies is extremely expensive ($330 / tube, about the size of a small tube of toothpaste), and is manufactured to not only act as an extreme dieelectric grease, but to be waterproof, and lubricate the switch contacts without gumming up or sticking for the rest of the vehicle's life. Plus, the grease is actually applied to the internals of the switch via a special syringe in a special procedure that applies it to all contacts and slides. Afterwards, one-way screws are installed to deter anyone from tampering. Your best bet is just to take the vehicle in and have it done...they don't charge anything, and it's your safest bet.
    Quote Originally Posted by jbroas View Post
    As far as fires, I believe there has been a few, but as far as I know all of them have been caused by someone using their own lubricant on the switch contacts. That being said, I had to replace two circuit boards (out of hundreds checked) during this recall due to burnt contacts; neither of which was ever disassembled by the customer (or so they say). So it's very unlikely that you'll see a problem any time soon, but the threat is still there. As far as your unmentionables under the hood, I wouldn't worry. Most dealers won't even open the hood to do the recall (some might to top off fluids as a courtesy), and even if they do, it's very unlikely they would document anything to intentionally void your warranty; the only time they might document something like that is if your truck is in for a warranty concern that's directly affected by the turbo setup.
  11. Thanks jbroas "Thanks for this post"
  1. Toyota Tundra Best Fuel Economy A/C or Windows Down
    Last Post: 05-01-2013, 05:29 AM
  2. Clutch Fan vs Electric
    By MPToy07 in forum Performance & Handling
    Last Post: 10-09-2012, 06:22 AM
  3. power windows
    By shady08798 in forum Questions/Help/Schematics
    Last Post: 11-16-2011, 09:22 AM
  4. Tell The Kids Its OK To Touch The Windows in Your Toyota
    Last Post: 07-28-2011, 06:04 PM
  5. FJ Rear windows that open !
    By ramoine in forum OEM/Aftermarket Parts/Accessories
    Last Post: 02-11-2011, 09:55 PM
