Thanks Thanks:  7
Page 1 of 3 123 LastLast
Results 1 to 12 of 33
Thread: G-Tek SABM Kit Installed, simple.
    06-02-13
    7
    $5495
    Default G-Tek SABM Kit Installed, simple.
    I installed my SABM i got from Dez today, and it was pretty simple, finding a 3" bi metal hole saw in canada cost just as much as the kit, i ended up paying $10 for a wood/plastic one from canadian tire that with a little extra effort cut through the metal.
    With a few trips to the store during the install, (and working on my other car, Noticing that it has 2 ripped CV boots in the process) it took overall longer time, but hey, got me some new tools, I think i cut the hole just a tad too high as the K&N air filter wouldnt fit right, but some a little bit of hammering and jiggling got it in, not perfect but i dont see it causing any problems.
    Only issue i had and i dont know why, when i started the truck up after connecting everything, it fired and stalled right away, then fired right up to normal on 2nd try, did it again when i disconnected everything when i had to readjust for filter.
    Ill see how my MPG goes in about a week or so
  2. Thanks Rut, Ltsampson "Thanks for this post"
  3. #2
    08-30-09
    $17170
    Default Re: G-Tek SABM Kit Installed, simple.
    Keep us posted on what differences you notice.I've got Dez's kit on "the short list" but haven't been able to order it yet.
    06-02-13
    7
    $5495
    The first test for MPG havent turned out too well, the first with around 225 miles, about 1/3rd highway at 50MPH(was following our classic car home), 1/3rd highway at 62mph and 1/3 city turned a 17.5 MPH
    To my lake an back which was over 250 miles, though i got slowed down twice to a crawl for 10 mins once and 30 mins the other time, 5kms of low 4wd, and passing one car speeding up to over 80, got 18.5 MPG,ill try later on with hopefully better runs as i was able to hit over 20 mpg without the SAMB
    25,391
    368
    Wait.. What? You lost mpg? You sure?
    This is the first I've heard of a loss.
    06-02-13
    7
    $5495
    My previous drives on this route, i barely did any 4wd, once a little, no heavy accelerating, constant speed of 60mph with no real stops of long idling time, so its kinda comparing apples to oranges at the moment
    TG Platinum VIP fester's Avatar
    01-04-09
    British Columbia
    3,089
    $61166
    59
    Deception!!! Where are you located. I am smack dab in the middle of BC, Prince George
    Mods to date:
    -rad guard
    -flat black engine cover
    -flat black grill emblem
    -Raider Vagabond Canopy
    -Aries Step Bars
    -stock air box mod
    -lights in grill
    SPLENDOUR SINE OCCASU
    Rookie clutch's Avatar
    10-06-12
    Fort St John, B.C.
    74
    $12925
    8
    My truck did the stall on the first start after I installed my cai. It must just be something with the vacuum hoses or the maf sensor.
    2013 Double Cab Long Box in Magnetic Grey Metallic. Procomp 3/1 levelling kit, AFE Cold air intake, BHLM, Debadged, Black BackRack headache rack, Black UWS toolbox, Line-X'd box, G-Tek door sill protectors, Weathertech floor liners, Tekonsha P3 Trailer Brake controller, 275/70r18 Goodyear Duratracs, Pilsner Bunny air freshener.
    Seasoned Veteran
    Rut's Avatar
    PA
    3,757
    $64396
    70
    Quote Originally Posted by clutch View Post
    Not sure why it happens but it happens to others as well
  10. #9
    25,391
    368
    Quote Originally Posted by Rut View Post
    Are you guys talking about stalls after the SABM install or after a CAI install?
  11. #10
    10-06-12
    Fort St John, B.C.
    74
    $12925
    8
    I am saying it happened when I did my cai and believe it was probably from disconnecting and reconnecting either the mad sensor or vacuum lines. If you disconnect these while installing the sabm then I feel that would cause the stall problem for you. It only happened to me the very first start after I installed my cai a few months ago and I have had no problems since.
  12. #11
    25,391
    368
    Ahhh gotcha.
  13. #12
    hooper_design's Avatar
    08-29-12
    330
    $12750
    12
    any tricks or tips on cleaning the MAF sensor? I have heard the non conductive computer/chip cleaner from radioshack works very well..I plan on cleaning my truck this weekend in side and out, and this is on the list.
    2007 SR5 DC 5.7/V8 Salsa Red
    89k Miles
    BAmuffler Custom Exhaust
    Debadged
    Mesh grille
    Line-X Bed Liner
    Tinted front and back windows
    Carbon air filter removal
    Soft tri-fold tonneau cover
    Swapped to OEM JBL Navi
    10 inch Kenwood Excelon with JBL GTO Amplifier
    Interior LED swap
    MaxTrac 2.5" Leveling Kit
    SABM mod
    BHLM Depo headlights
    Under the dash/seat LED's
    18" MD Vortex Wheels
    295/70/18 Nitto Trails
    More mods to come
  1. G-Tek SABM kit installed today
    By cdev30 in forum Customer Reviews and Testimonials
    Last Post: 08-06-2013, 01:27 PM
  2. A simple, yet complex tire question
    By Ivan in forum Wheel & Tire Fitment Questions & Info
    Last Post: 08-27-2012, 05:56 AM
  3. Simple Truth Ė Hybrid Owners Donít Buy Another
    Last Post: 04-17-2012, 03:52 AM
  4. Proryde! Simple, Affordable, Adjustable, Leveling!
    By Dez in forum Front Page News & Announcements
    Last Post: 10-13-2010, 07:13 AM
