Post Thanks / Like - 1 Thanks
I'm assuming this will work with the trd kit too since it uses the OE bottom half? I'll take one if so!
Re: SABM Kit.. Need a Measurement
Yes it would Joe seeing the only modification to the air box is done on the bottom piece.
Shoot me your shipping address and I'll get one to you this week.
I'll buy in if you want!!!
Check out my dyno graphs and track times
here
Hay dez I am willing to help also. Let me know if you still need help with this.
Sent from my iPhone using Tapatalk 2
TRD SUPERCHARGER
TRD DUAL EXHAUST
TRD Sway bar custom powdercoat blue
PRO COMP 3/1 LEVEL KIT
PRO COMP 305/60/18 TIRES
KMC HOSS 18 IN WHEELS
CUSTOM TRD INLAY IN CENTER OF WHEELS
COLOR MATCHED BREAK CALIPERS
OEM NAVIGATION
BACK UP CAMERA,AND BACK UP SENSERS
AFTERMARKET REAR ENTERTAINMENT CENTER
TECH12VOLT SUB BOX
2 10IN KENWOOD SHALLOW SUBS
KENWOOD 1000W AMP
G TEK FAB SABM KIT
AND MANY MORE TO COME
Platinum Member
- Rep Power
- 145
2007 Crewmax
SABM G-Tek Kit
Painted Fender Flares
Flowmaster 40's
TRD Swaybar
Bedrug covered with a BakFlip
305/65-18 BF Goodrich
Daytime Foglight mod
CCFL Headlights
HID Lows/Fogs
Spyder Taillights
Dynamat and Ensolite Cabin and Doors
JL Audio Clean Sweep,Polk 6x9 front and 4 ways 6.5 in the back, and Sony amp for tunes.
American Outlaw Regulator rims, 20x9
Nitto Ridge Grappler LT295/55R20
here
Before and after dyno results would also be nice from one of you guys.
I can do that. Got a dyno day coming up May 11. Think you'll be able to have it to me by then?
here
- Rep Power
- 0
Need any more test dummies?
When I send them out to you guys I'll need some clean pics from all of you for instructions.
I suggest using a 3" od hole saw for the best installation.
Pics I need..
* Disconnecting the battery.
* Relocating the group of ground wires slightly to the left of where they're at. (You'll see them and understand what I mean very simple)
* 3" OD hole saw cutting the hole in the air box base as well as the fender wall.
* Rest of installation.
Holding the flange in place inside the fender compartment while you slip on the tube may require a helping hand unless you test subjects can figure out an easier way.
