Tundra News, Reviews, & Information
- Rep Power
- 12
2007-12 Toyota Tundra Rear Rubbing or Grinding Turning Noise – TSB
Does your 2007-2012 Toyota Tundra have a rubbing or grinding noise from the rear when turning? If so, Toyota has released a technical service bulletin (TSB) to address this issue. The T-SB-0013-13 addresses a condition where “some 2007 – 2012 model year Tundra vehicles may exhibit a rubbing or grinding noise from the rear when [...]
The post 2007-12 Toyota Tundra Rear Rubbing or Grinding Turning Noise – TSB appeared first on Tundra Headquarters Blog.
More...
Re: 2007-12 Toyota Tundra Rear Rubbing or Grinding Turning Noise – TSB
PM me about G-Tek Fab Door Sill Protectors and SABM kits for your 07+ Tundra>>> PM Dez
Same here. I've installed a few of these kits before though for rear wheel bearing noise (same part number for the kits), they are pretty labor intensive. Definitely not something that can be done in your driveway!!!
"The Professor"
BHLM with Morimoto Mini D2S projectors, DDM/Morimoto 5K 35W HID low-beams and fogs
TRD Supercharger, URD MAF Calibator, G-Tek Fab SABM Kit
Diamond Eye dual 3.5" exhaust
4.30 gear swap, Auburn Gear Pro LSD
516 RWHP, 522 TQ
1/4 mile - 12.726 sec @ 107.79 MPH on street tires
Post Thanks / Like - 1 Thanks
Originally Posted by
MPToy07
I'll take that bet!!!
redyota
You're on!!! The kits are $300+ per side online ($400+ per side retail). You buy one kit (Left or Right, you choose), and PROVE that you didn't take it anywhere to have any portion of the job done, and I will personally ship you a case of your favorite brew!!!
Part numbers are 04002-4310C for the right side, and 04002-4320C for the left side. They're both equally hard. Ready...set...GO!!! Haha
"The Professor"
516 RWHP, 522 TQ
Three hundred bucks a case? Must be Italian beer?
I have a factory manual, is that cheating?
redyota
Like I said...your choice!!!
redyota
Nope!!!
"The Professor"
516 RWHP, 522 TQ
