Below Header Tire Rack
Results 1 to 8 of 8
Thread: Towing - Wiring/Connection
    07-21-12
    Outside of Dallas/Ft. Worth TX
    $5185
    Default Towing - Wiring/Connection
    Well, it's been some time since I initially said hello to y'all. But I'm back now with this question. I bought my truck used. But based upon the owner's manual, I think this issue is a factory made one. The truck has come with a 3 prong connection (yes, that's correct, I did say 3 prongs). The tow wires are "built into" the side wall of the driver side tail light. So, per the owner's manual, I have to pull the wires underneath the tailgate to make a connection. My problem is that I need to pull a trailer with a modern connection. I have spoken to the dealer and they seemed to be shocked by this notion. They were expecting a 4 prong connection. So I am wondering if any of y'all have experienced this. If so, how did you convert it to a modern connection? I have a 2000 2dr V6 with 8 ft. bed.
    bigTex
    Tundra 2000 V6 - tow package
    07-21-12
    $5185
    Default Re: Towing - Wiring/Connection
    Ok...I saw the dealer. And I found out the 3 prong must have been the previous owner mod. I discovered that a 7 pin receptacle was hidden behind the bumper and that I need a connecting wiring harness and "outlet" for the trailer connection. Any recommendations on where I can find a harness kit. The ones I have found so far have plastic covers. I'd like to find one that has a metal "outlet" and metal cover if possible. I see that towing has several options - 4 pin and 7 pin and converters for 7-to-4 or "dual outlets".
    bigTex
    TG Super Moderator tonyspin's Avatar
    2,370
    $68458
    46
    First of all, does your trailer have brakes? If it doesn't have brakes, this is what you need to go from your 7 pin to a flat 4 pin
    http://www.ebay.com/itm/ONE-7-WAY-RO...94e6ed&vxp=mtr
    TG Gold VIP redyota's Avatar
    03-06-12
    677
    $12375
    12
    thats . my oem tow hitch package has both connetions next to the hitch.
    its way handy!
    2,370
    $68458
    46
    Quote Originally Posted by redyota View Post
    its way handy!
    His is a gen 1
  6. Thanks redyota "Thanks for this post"
    Resident Toyota Tech MPToy07's Avatar
    Marquette, MI
    1,043
    $14390
    20
    The wiring you're seeing is probably aftermarket, and I say that for two reasons;
    1) It being tucked away under the vehicle somewhere
    2) I don't believe the 2000 V6 came with a 7-pin connector.
    To better understand what you'll need to complete the wiring and connections, I'll need to see a couple pics of what you currently have, and what you're trying to connect to.
    "The Professor"
    BHLM with Morimoto Mini D2S projectors, DDM/Morimoto 5K 35W HID low-beams and fogs
    TRD Supercharger, URD MAF Calibator, G-Tek Fab SABM Kit
    Diamond Eye dual 3.5" exhaust
    4.30 gear swap, Auburn Gear Pro LSD
    516 RWHP, 522 TQ
    1/4 mile - 12.726 sec @ 107.79 MPH on street tires
    03-06-12
    677
    $12375
    12
    Quote Originally Posted by tonyspin View Post
    His is a gen 1
    i see.
    i have the 2nd gen...
    TG Super Mod mblair77's Avatar
    02-14-09
    Syracuse, New York
    1,613
    $112939
    34
    Did you get this figured out?
    Sent from my 3rd gen iPad using Tapatalk HD
    2013 MGM CM
    TOO MANY MODS TO LIST - CHECK OUT MY BUILD THREAD HERE
    http://tundrageeks.com/forum/showthread.php?t=8686
  1. Wiring under passenger seat
    By Corysm in forum Tundra Lighting Inside & Out
    Last Post: 01-11-2012, 07:51 PM
  2. I need help with jbl nav wiring.
    By NEW MEXICOS BEST in forum Tundra Electronics/Window Tinting/Vinyl Graphics
    Last Post: 05-08-2011, 01:28 PM
  3. A Must For 4 Stroke Riders by Works Connection
    By Dez in forum Genral Dicussion
    Last Post: 05-11-2010, 08:03 AM
