Results 1 to 12 of 14
Thread: Cam Position Sensor - Circuit Malfunction
    Rookie Prizmatik's Avatar
    09-08-12
    Ontario, California
    46
    $6320
    Default Cam Position Sensor - Circuit Malfunction
    I have a 2000 Tundra 4.7, and I have a check engine light for the above mentioned trouble code. I have removed the sensor and check it for resistance, and it is within tolerance. Anybody know of any common issues with this sort of thing? Thanks in advance.
    Default Re: Cam Position Sensor - Circuit Malfunction
    Do you have the exact code number? Should be something like P0### or P1###. This will tell you whether it's a bank 1 or bank 2 sensor. Also, you may have trouble starting the truck if you're losing one of the cam sensor signals. This would be the best time to measure your resistance, in case it's an intermittent failure. I've never heard of camshaft sensor codes on the older models, hopefully it just turns out to be a sensor issue. Good luck and let us know what you find!!!
  3. Thanks Gutz "Thanks for this post"
    09-08-12
    Ontario, California
    46
    $6320
    Thanks for the reply. The code is P0340. I have checked the resistance, and it is within operating range. I have tested the voltage coming from the electrical plug, and I have zero voltage.
    Tundraddicted since 2007!
    Gutz's Avatar
    12-11-08
    SoCal
    7,182
    $169866
    115
    MP is a tech for Toyota, I'm sure he'll chime back in soon.
    Franky
    12 Second Tundra<--- Clicky
    09-08-12
    Ontario, California
    46
    $6320
    I am not too experienced with electrical trouble shooting, but did try my best to find some clues. I checked for continuity on both terminals of the plug going into the wiring loom. 1 terminal had continuity on just the positive. BUT...the other terminal had continuity on the positive and negative. That surely doesnt sound good to me. Is there a way I can test the ECU if its bad???
    Gutz's Avatar
    12-11-08
    SoCal
    7,182
    $169866
    115
    Test the ECU, hmm. I don't know, besides swapping it out with a know good one, there MIGHT be a tool you can plug into it and test it???
    Franky
    Hey I'm back!!! Finally got a chance to check things out at work. Been busy this week, replacing the frame on an 02 Tundra, so I pretty much know the first gen inside n out right now lol. I checked out the code and it reminded me that you only have one camshaft sensor. I believe the cam sensor generates its own signal voltage, so you won't see any voltage from the computer. Most of the issues I've seen is with the cam sensor itself. Even though resistance may be good, the shielded wire could be broken, causing interference from other components. The only other issue I've seen is the tooth broken on the cam pulley itself, but this usually only happens when someone does the timing belt wrong and snaps it off. The first thing I would do is replace the sensor itself, and go from there.
    09-08-12
    Ontario, California
    46
    $6320
    Thank you, I appreciate the guidance. I will look for a cam sensor, and definitely get back to let you guys know if that worked.
  10. #9
    09-08-12
    Ontario, California
    46
    $6320
    Forgot to update the thread. I replaced the cam sensor, but didnt fix my issue. BUT.......I realized I accidentally swapped the cam gears No more cam sensor trouble code now
  11. #10
    Gutz's Avatar
    12-11-08
    SoCal
    7,182
    $169866
    115
    Haha, nice!
    Franky
  12. #11
    Simple mistake with an easy fix...AND you know you have a good sensor in there now!!! How's the truck running?
  13. #12
    09-08-12
    Ontario, California
    46
    $6320
    Truck is running a lot better, and starting reliably and consistently. I know why I got them backward. When I began to replace the head gasket, I labeled the cam gears according to how I was looking at the truck. Well, as I read on, in the Chilton Repair Manual, the cam shafts, cylinder heads, and other parts, are named either right side or left side (right side=passenger side/left side=driver side), just the opposite of how I labled my cam gears. Well...when I reinstalled all the parts, I was in Toyota thinking mode, and reinstalled the cam gears on the wrong side. Lesson learned.
  1. Tire Pressure Sensor scam or coincident?
    By WLRay in forum Wheel & Tire Fitment Questions & Info
    Last Post: 01-06-2015, 10:35 PM
  2. American Racing Circuit Wheels
    By Marky Mark in forum Tundra Wheels, Tires & Brakes
    Last Post: 02-04-2011, 08:19 AM
  3. Interest in a Circuit Track meet?
    By cater in forum SouthEast
    Last Post: 10-28-2010, 06:13 PM
