Below Header Weathertech
Results 1 to 7 of 7
Thread: Tires - shaking the truck (wheel covers?)
    07-21-12
    Outside of Dallas/Ft. Worth TX
    $5185
    Default Tires - shaking the truck (wheel covers?)
    Hello. I was wondering if anyone had some experience with tires being difficult to balance.
    I had 6 attempts at several places that tried to balance them (one visit even rotated tires from front to back) but couldn't fully take out the shaking on the front end. I even bought new front tires to see if it made any difference. It helped some, but even so, the shaking is still there.
    I finally went to my local dealer to have it addressed. I was told the following: the best tire size is to use stock size of 245/70/R16. I bought my 2000 Tundra used with tires on it already at P265/70/R16. I purchased 2 new front tires to see if it would help. The new tires are LT265/75/R16. I was a bit concerned about the extra 5% causing the wheel to be too big to complete full turns left and right, but so far seems to work.
    Now, the dealer gave me this advice....If they take of the wheel covers, it helps to reduce the vibration. The trick with the older rims on the truck now, is that they do not have a whole in them to allow the newer machines to balance the whole wheel (cover included). Since these are older covers, they can only only balance the tire and rims. But putting the cover back on changes the balance characteristics so much that the cover can cause the tire to act out of balance again.
    So, my question is this....has anyone experienced a tire cover being too heavy to interfere with a proper balancing?
    Any input/feedback is greatly appreciated.
    Thanks Y'all,
    bigTex
    Administrator Dez's Avatar
    20,833
    $100273950
    295
    Default Re: Tires - shaking the truck (wheel covers?)
    I don't buy the hub cap Too heavy story at all...
    Did the dealer happen to mention possible warped brake rotors?
    PM me about G-Tek Fab Door Sill Protectors and SABM kits for your 07+ Tundra>>> PM Dez
  3. Thanks KrytikalCare "Thanks for this post"
    TG Gold VIP Tundraholic08's Avatar
    12-27-08
    East, TX.
    566
    $25130
    15
    Yes it could be do to warped rotors?
    Sent from my iPhone 4s using Tapatalk
    __________________________________________________ __________________________________________________ ________________________
    2008 Toyota Tundra Double Cab with TRD Off-Road Package..Desert Sand Mica Color...
    Mods: Viper 5500 Remote Start, Volant CAI, TRD Sway Bar, Corsa Sport Exhaust System, OBX Long Tube Headers w/ URD Y-pipe, Unichip RSpeed w/ 5 Maps..
    SERENITY- 4 Wheels Move The Body, 2 Wheels Move The Soul...
    Novice Fenrir Wolf's Avatar
    05-13-12
    Yuma, Az
    203
    $10420
    4
    On a previous vehicle when I brakes, however slight, the steering wheel shook. I replaced the rotors and it stopped.
    Tundraddicted since 2007! Gutz's Avatar
    12-11-08
    SoCal
    7,164
    $169586
    109
    Did this just start to happen out of nowhere?? Maybe the front suspension is damaged or something?
    Franky
    12 Second Tundra<--- Clicky
    07-21-12
    $5185
    Well, it's been some time since I last posted my question. I would have replied sooner, but life just happens.
    After putting on new tires, most of the vibration has been resolved. Now there is just a slight vibration at hwy speeds. Brought to dealer and they did a road force balance. I started with a shake that would vibrate the steering wheel about 1/2" between the left-to-right sway. (Original tires when truck was purchased). I got the new tires on LT265/75/16's. Load range E. I plan to use it for hauling stuff, not just a commuter truck. (Manufacture sticker says to use P245/75/16R) In the end, I still have a slight vibration, (maybe a 16th to an 8th of inch). So I am chalking it up to an empty bed. At this point, my Tundra is a second vehicle, so I don't drive it alot. Maybe a couple times a month. Now with new tires, it's going to be hard to answer the uneven wear question. I'll have to drive it more to let you know. When balancing we confirmed rotors are OK and no bent wheels. I have 2000 2DR V6 with an 8'ft bed. It has a tow package added on.
    bigTex
    Tundra 2000 V6 - tow package
    Rookie 1ATony's Avatar
    02-16-10
    98
    $2285
    5
    Welcome to the site
  1. Can't drive 55 w/o shaking
    By Highrider in forum 2007+ Tundra Issue Discussion
    Last Post: 02-07-2012, 08:34 AM
  2. Car/truck covers
    By NEW MEXICOS BEST in forum Shells/Campers/Bed Caps/Bed Boxes/Truck Covers/Bed Liners
    Last Post: 08-23-2011, 05:08 PM
  3. Shaking between 30/45mph
    By MaynardJamesKeenan in forum 2007+ Tundra Issue Discussion
    Last Post: 06-26-2011, 06:34 AM
  4. Truck Covers USA - American Roll Top
    By LCBrewing in forum Shells/Campers/Bed Caps/Bed Boxes/Truck Covers/Bed Liners
    Last Post: 07-01-2010, 09:05 AM
