Thread: DIY: FJ CRUISER TOTAL CHAOS UCS's: Inst. w/pics
    Platinum Member
    crzy2bealive's Avatar
    02-10-10
    Anaheim, California, United States
    14,125
    $118187
    210
    tools DIY: FJ CRUISER TOTAL CHAOS UCS's: Inst. w/pics
    Installing Total Chaos Upper Control Arms (UCA) on a FJ Cruiser
    Removing factory UCAs (ref.: FSM 02600410):
    1. Chock rear tires
    2. Lift vehicle and place jackstand under frame
    3. Remove wheel and tire
    4. Support front Lower Control Arm (A arm)
    5. Retain spindle with wire or rope to prevent spindle from falling away when upper ball joint is removed
    6. Remove bolt holding ABS wire bracket; remove wire from bracket (bracket is not re-used)
    7. Remove cotter pin and remove nut holding the upper ball joint to the spindle (Exercise care since nut is fairly soft and may be rounded easily)
    8. Use ball joint separator to detach upper ball joint from spindle (a pickle fork may also be used)
    9. Loosen nut on UCA pivot bolt
    10. On driverís side, loosen battery and place wedge under battery and detach wiring harness from bracket next to battery; on passengerís side detach AC line from plastic bracket to make room for the pivot bolt removal
    11. Remove pivot bolt and the two washers
    Remove balljoint from spindle using a balljoint separator
    Installing Total Chaos UCAs:
    1. Thread pivot bolt through washer, front UCA arm, washer, UCA mount on frame, washer, rear UCA arm, washer (make sure ABS wire is outside of UCA)
    2. Install nut onto pivot bolt and torque to 85 ft-lb
    3. Insert adaptor onto spindle
    4. Insert bolt through upper misalignment spacer, uniball, lower misalignment spacer, spindle adaptor, washer
    5. Install nut and torque nut to 100 ft-lb
    6. Zip-tie ABS wire onto rear of TC UCA
    7. Grease polyurethane bushings at zerk fittings with synthetic grease such as Redline CV-2 or SuperLube
    8. Spray Tri-Flow teflon lubricant onto uniball
    9. Cycle UCA to make sure thereís no interference and there is slack in ABS wire
    10. Install wheel and torque wheel nuts to 85 ft-lb
    11. Lower vehicle
    12. Repeat on the other side
    13. Inspect and adjust front alignment
    Thanks to TCAO and from www.fjcruiserforums.com
    Platinum Member
    02-10-10
    14,125
    $118187
    210
    Default Re: DIY: FJ CRUISER TOTAL CHAOS UCS's: Inst. w/pics
    this write up would prob work for tundras just need to double check torques
  1. DIY: FJ CRUISER WHEEL BEARING REPLACEMENT: Inst. w/ pics
    By crzy2bealive in forum FJCruiser Country
    Last Post: 11-06-2011, 08:07 AM
  2. 07 Tundra Total Chaos LT
    By Dez in forum Desert Off Road
    Last Post: 05-06-2010, 08:23 PM
  3. Total Chaos 07+ Toyota Tundra Vid
    By Dez in forum 4X4/Long Travel Suspensions/Lift Kits
    Last Post: 03-04-2010, 09:58 AM
