Results 1 to 5 of 5
Thread: TPMS/ cruise control
    02-24-20
    4
    Default TPMS/ cruise control
    2007 Tundra SR5 5.7...My TPMS light flashes for one minute and stays on steady. My cruise control doesnít come on and thereís no fuse that I can find. Will the TPMS light on stop the cruise control from working? Thanks in advance.
    Iím still trying to figure out how to **** the TPMS light off as well All I have is an OBD2 scan tool. Iím thinking I need tech scan. Also I have no DYC codes
    Gain, Thanks!
    02-24-20
    4
    Default Re: TPMS/ cruise control
    No DTC codes.
    820
    22
    Basic OBD 2 readers will not clear those codes. I ended investing in the bluedriver obd scanner which does clear it up, but it has to be reset every time you turn on the truck.
    My TPMS does the same thing, flashes for a minute and stays on, because all my sensors have died, confirmed via America's tire....
    The cruise control may be a little more intricate, since I may need to ask a variety of questions, like are you the original owner?? If you're did it work before, or is it a recent issue?? if you're not, Some people do swap over steering wheels with the cruise option to add later and due to cost, just drop it all together, or may have been wrecked with airbag deployment and sourced said steering wheel and swapped it over. If it worked before you may have issues with the body ECU which does hold certain options in its software. You may need to check additional fuses under the kick panel and under the dash. Hope this helps some.
    820
    22
    You may need to look at your grounding points, so you may need to trace the wire, I believe is fuse 27 or 29 under the hood, I'll post some pdfs around 830PST since I'm on my way out of the door, and the info is on my computer not my phone. These may give you some guidance on troubleshooting... other wise, may be worth a 300$ diagnostic bill at the stealership.
    02-24-20
    4
    Thanks. Itíd be very helpful to have diagrams. Iím told thereís no fuse for the cruise control system. Iíve pulled the steering wheel and checked all connections. All seem good. Iíve finally got the tpms light off after changing g a bad sensor but the cruise still doesnít work. Thanks for the help!
  1. Dynamic Radar Cruise Control (DRCC) | Toyota Safety Sense | Select 2016 Models | Toyo
    Last Post: 10-27-2015, 06:21 PM
  2. Tpms
    By CFC in forum Wheel & Tire Fitment Questions & Info
    Last Post: 09-08-2011, 08:00 AM
  3. July 16th Galveston Cruise
    By gpend5.7sport in forum SouthWest
    Last Post: 07-15-2011, 09:17 PM
