Thread: My 06 Limited DC
    12-23-19
    Default My 06 Limited DC
    New member, I have had my 06 Limited DC for 5 years. Truck had 80k miles when I purchased, now has 145k. I had to replace the engine because of a blown head gasket this past summer. The refurbished engine that I purchased only had 65,000 miles, I went ahead and done the timing belt water pump replacement, the kit I purchased was made by Gates. Have custom grill with TRD badge. Installed weather tech bug deflecter & avs rain guards. Replaced OEM fog lights with cubed LEDs. Have lift leveling kit, 3" front 1" rear. Also have adjustable rancho front an rear on 2nd setting. Recently redone entire front end, upper & lower ball joints inner and outer tie rods. Used all Moog front end parts then aligned her. Couple weeks ago I added 17" XD monster wheels w/ 305/65 BFG ko2's, & running 2 inch wheel spacers front and rear. K&N cold are in tank with flowmaster exhaust. I ordered a bull bar off of Amazon has a built-in light bar already have the wiring installed in a put in a OEM push button switch.
    Plan is to re paint her this spring and in the meantime I will remove all badges.
    I plan to do the rear brake conversion and upgrading the sound system. Also going to try to add heated seats and push button start. Probably get new front and rear light assemblies in a smoke or tinted color.
    Any suggestions or advice on mods y'all recommend is more than welcome.
    Sent from my moto z4 using Tapatalk
    4,294
    Default Re: My 06 Limited DC
    Purchase Revtek's REV7506 lift kit and get a 4WP Promotional Gift Card for up to $180
    Welcome to the group!! Nice looking truck!!
  1. new to me 08 Tundra SC DC 4x4 Limited
    By motorhead_1 in forum NEW MEMBER INTRODUCTIONS, Site Rules & Info
    Last Post: 12-16-2013, 12:50 AM
  2. First Tundra! 07 5.7 TRD limited
    By TRD27 in forum NEW MEMBER INTRODUCTIONS, Site Rules & Info
    Last Post: 03-20-2013, 12:31 PM
  3. New Member From N.Cal (1st gen TRD Limited 2WD)
    By The_Josh in forum NEW MEMBER INTRODUCTIONS, Site Rules & Info
    Last Post: 11-26-2011, 04:09 PM
