Results 1 to 5 of 5
Thread: Rear window no longer responsive
    05-23-19
    Default Rear window no longer responsive
    I have a 2010 platnium tundra with a power rear window. The rear window no longer works but all of the rest of the windows still do. I cant seem to find a fuse specific to just that rear window ( but maybe im missing it). Have you heard of this happening to others and also are there some steps i can do to trouble shoot to maybe find out what the issue is? Also just before it stopped responding it was starting to intermittenly work but now has completely stopped ( not sure if that helps with what happened but figured id ask. Thanks for any help you can provide!
    792
    Default Re: Rear window no longer responsive
    Sounds like a recall issue. I had it happen on my 07 double cab, all my windows got stuck open.. A lot of fun.. All my switches were replaced since the master was toast. Recall pasted below.
    Power Window Master Switch may Melt
    If the sliding electrical contacts are not protected by lubricant, debris and moisture that get into the switch may cause a short circuit and the switch assembly may overheat and melt, increasing the risk of a fire.
    NHTSA Campaign Number: 15V689000
    Manufacturer Toyota Motor Engineering & Manufacturing
    Components VISIBILITY
    Potential Number of Units Affected 1,814,284
    Summary
    Toyota Motor Company (Toyota) is recalling certain model year 2009-2011 Tundra, Sequoia, Corolla, Corolla Matrix and Scion xB, 2008-2011 Highlander and Highlander Hybrid, 2007 Camry and Camry Hybrid, 2009 Camry and Camry Hybrid, 2006-2011 RAV4, 2006-2010 Yaris, and 2009-2010 Scion xD and Pontiac Vibe vehicles. During the manufacturing of the Power Window Master Switch (PWMS), grease lubricant may have been inconsistently applied to the sliding electrical contacts.
    Remedy
    Toyota will notify owners, and dealers will inspect the switch, applying a lubricant if no abnormality is found. If abnormality is found, the PWMS circuit board will be replaced, free of charge. The recall is expected to begin December 20, 2015. Owners may contact Toyota customer service at 1-800-331-4331. Toyota's number for this recall is C0M.
    Notes
    Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
  3. Thanks Dez "Thanks for this post"
    25,372
    367
    Yup sounds like it might be a master switch meltdown. I keep getting notices from Toyota to go have mine fixed only I haven’t experienced the issue.
    792
    LOL, I did, I think I even posted it on here... it was raining and then snowing and my windows were stuck open about 3 inches...
    25,372
    367
    I think I remember. Too funny.
  1. Waterspots on rear window
    By Mongo40 in forum Tundra Wash, Wax, and Detailing
    Last Post: 10-01-2013, 08:43 PM
  2. Sliding rear window
    By jgalloway79 in forum NEW MEMBER INTRODUCTIONS, Site Rules & Info
    Last Post: 08-02-2012, 03:02 PM
