Results 1 to 4 of 4
Thread: 2005 Rear Brake Swap
    05-15-19
    2
    Default 2005 Rear Brake Swap
    $70 off INSTANTLY on BFG All-Terrain T/A KO2's
    Can the 2005 Sequoia factory rear disc brake components be used as a direct replacement for the 2005 Tundra rear drum brake components without having to change out the Master cylinder, proportioning and ABS units? Anybody done this to improve braking on the PU?
    Sent from my iPad using Tapatalk
    12-23-19
    3
    Default Re: 2005 Rear Brake Swap
    Quote Originally Posted by Rog View Post
    I'm interested in this same topic. I have a 06 Limited DC, I tow quite a bit and have heard switching the rear from drum to disc makes a significant difference.
    Sent from my moto z4 using Tapatalk
    4,300
    83
    This kit will replace drums with late model 4 Runner disc setup.
    https://www.silverminemotors.com/toy...e-with-e-brake
    Good luck!!
    blackdemon's Avatar
    11-20-08
    NorCal
    801
    $21544
    22
    I'm pretty sure they will retrofit since most components are shared across the 3 platforms the Tundra, Sequoia and Land Cruiser and their Lexus twins.
    I hope you mean change the rear brakes from the knuckle outward, you may need longer bolts to bolt on, as I'm doing something similar a direct swap on my Celica GT with drum brakes to disc brakes from the same year Celica GTS and they do require longer bolts to fit through the knuckle .
    Not sure if it affects your ABS, but on this end there is no need to change the master cylinder, but then again it is a smaller car with no ABS. Hope this helps somewhat.
    TLDR,
    Retrofit yes,
    Master Cylinder and ABS unit needs more research
    (. Y .) my anti-drug
    Mods
    -Front License plate removed
    -FJ Cruiser Running Boards
    -White Turn signals
    -Truck Covers USA Roll Cover
    -Laufenn XFit AT 275/65-R18
    -TRD anti-squat bar
    - Optima Yellow top
    Up coming Mods
    -VLED interior lights
  1. 2000 tundra rear brake covershion on 2wd reg cab p-up
    By joe in forum Wheels, Tires & Brakes
    Last Post: 05-16-2017, 06:38 AM
  2. Extended Rear Brake Lines
    By Ill10DC in forum 4X4/Long Travel Suspensions/Lift Kits
    Last Post: 11-04-2010, 04:21 PM
  3. TRD Big Brake Kit for 2005-2006 Tacoma X-Runner
    By TacoMEDIC in forum Parts/Accessories
    Last Post: 05-26-2010, 03:28 PM
