Thread: 2005 Access Cab 2WD TRD Brakes
    05-14-19
    2
    Default 2005 Access Cab 2WD TRD Brakes
    $70 off INSTANTLY on BFG All-Terrain T/A KO2's
    Hi All,
    Considering a major revamp of stock brake system (vacuum boost with discs & drums) to either electric or hydraulic boost units and 4 wheel disc brakes on all four corners. Any one out there get fed up with wuss stock system and gone through a custom upgrade like this? I could sure use some straight skinny and advice before I pull the trigger. Thanks.
    Sent from my iPad using Tapatalk
    4,254
    Default Re: 2005 Access Cab 2WD TRD Brakes
    Brake performance will definitely be improved but you are talking about expensive upgrades. If you push your truck to the limits, I guess it will be worth it.
  1. 12V/cigarette plug access
    By Mongo40 in forum Tundra Lighting Inside & Out
    Last Post: 01-28-2015, 07:31 AM
  2. Access Cab Owners
    By NetRickyAZ in forum 00/06 Tundra Issue Discussion
    Last Post: 09-20-2012, 08:16 AM
  3. First Generation Access Cab Sub Box Idea!
    By NetRickyAZ in forum Speakers/Subs
    Last Post: 04-30-2010, 07:47 PM
