Thread: Tire Size Advice
    03-22-19
    East TN
    Default Tire Size Advice
    $70 off INSTANTLY on BFG All-Terrain T/A KO2's
    I have the stock 17" wheels on my 06 DC Tundra, I also have the Bilstein 5100 shocks installed on the front on the 4th notch and its leveled my truck out. I currently have 265/65R17 Hankook Dynapro ATMs. I am getting close to needing new tires and want to put on 285/70R17s on. Has anyone tried with stock wheels and had success just worried about the sidewall of the tires rubbing on the stock upper control arms. I want to avoid wheelspacers at all cost.
    4,266
    Default Re: Tire Size Advice
    A 265 tire is about 10.5 inches wide. A 285 tire is about 11.25 inches wide. If you put the 285 tire on the truck it will be 3/4 of an inch wider, or 3/8 on each side of the tire. Check the distance you have now with the 265 tire and the 285 tire will be 3/8 of an inch closer to the UCA.
  3. Thanks austonb17 "Thanks for this post"
  1. Max tire size
    By BadBee in forum Wheels, Tires & Brakes
    Last Post: 05-28-2018, 03:05 PM
  2. Max tire size on an 07 tundra
    By JtMoney671 in forum Wheel & Tire Fitment Questions & Info
    Last Post: 06-19-2014, 03:29 AM
  3. what tire size am i looking for????
    By 08tundra in forum Wheel & Tire Fitment Questions & Info
    Last Post: 08-17-2013, 02:50 PM
  4. what tire size?? please help!
    By 08bluestreak in forum Wheels, Tires & Brakes
    Last Post: 05-22-2012, 05:28 PM
  5. Tire size calculator
    By JPNCA in forum Off Road Wheels & Tires
    Last Post: 08-05-2010, 12:10 PM
