Results 1 to 2 of 2
Thread: Secondary air injection pump question 2006 Tundra
    02-23-19
    1
    Default Secondary air injection pump question 2006 Tundra
    Hello everyone. I am a new member here. I have a 2006 Toyota Tundra and when I start it, I hear a weird noise. After watching some videos online, I am absolutely sure it is the secondary air injection pump making the noise. After reading, it looks like maybe the best option is the bypass kit? Will I be okay to drive the truck until I get the bypass kit and install it? The truck is still running fine now, itís just that the pump makes noise while the truck warms up.
    Thanks
    Sent from my iPhone using Tapatalk
    25,324
    366
    Default Re: Secondary air injection pump question 2006 Tundra
    Welcome to the forums!
    I would definitely go with the bypass kit option. Nothing wrong with tricking the ecu. I’ve read lots of reviews regarding the bypass and I’ve yet to come across anything bad to be said about this option.
  1. 2006 DoubleCab Limited backup camera install question
    By matai in forum 2000/2006 DIY Guides & Mods
    Last Post: 01-21-2016, 01:59 PM
  2. PO418 Secondary air injection system Relay "A" circuit.
    By Kameleonmax in forum 00/06 Tundra Issue Discussion
    Last Post: 10-26-2014, 12:06 AM
  3. Toyota Warranties Air Injection Pump System Ė Reimbursement Available
    Last Post: 07-08-2014, 06:51 AM
  4. Toyota Extends Air Injection Pump Failure Coverage to Certain 2012-13 Tundra
    Last Post: 06-15-2013, 08:09 PM
