Results 1 to 7 of 7
Thread: 2009 Tundra transmission issues
    01-19-19
    East Coast USA
    4
    eek 2009 Tundra transmission issues
    2009 Tundra 4x4 5.7 towing pkg.
    Transmission drive on 3rd gear no lights on the dash, only codes coming up are pending codes P0766, P0983, P0776 and P2714. Took it to dealership to do trans fluid change code P0983 went away, truck drove good for 3 days and codes P2714, P0776 & P0766 came back as pending. Change pressure control solenoid D (P2714) & solenoid for code P0766. Truck drove fine for 1 1/2 day and transmission will drive on 3rd gear. Follow the forums posts on how to change transmission fluid and check it. I'm in a lost right please advise.
    4,267
    81
    Default Re: 2009 Tundra transmission issues
    How many miles on that truck?
    01-19-19
    East Coast USA
    4
    165,000. When I change the solenoids I also change the filter. AT fluid that I use was Valvoline max life.
    4,267
    81
    You had the dealer change the fluid and they did not diagnose the problem?
  5. #5
    01-19-19
    East Coast USA
    4
    That is correct. The dealer also said that if it continues the don’t change the solenoids, that I was looking into a new transmission.
  6. #6
    01-19-19
    East Coast USA
    4
    Update took it to 2 different transmission shops, one was alike it might be a valve body or something inside the gears. The one that a took it today was an hour away from where I live and on my way there no issues. The shop had it all day running diagnostics and engaging the solenoids check fluids etc... the manager from the shop also said the the trans in the Truck is one of the bet working trans that he had seen in a while. Will keep updates as they happen.
  7. #7
    4,267
    81
    Maybe it fixed itself?
  1. 07, 5.7, dc 2wd transmission issues
    By doubleds65 in forum 2007/2013 Tundra Issue Discussion
    Last Post: 02-19-2019, 12:29 PM
  2. Replies: 11
    Last Post: 11-04-2016, 06:20 AM
  3. 2005 Tundra transmission shift issues
    By knolte57 in forum Ask The Professor!
    Last Post: 09-30-2014, 03:16 PM
