Thanks Thanks:  5
Results 1 to 10 of 10
Thread: Fuel tank mod/addon
    01-18-19
    Default Fuel tank mod/addon
    Can I add a 20 gallon metal fuel tank in the bed of my truck and make a drain through the bottom to the top of my stock tank is this possible I want to add some range to my truck I have a 6 inch lift and 35s its a 2007 limited 4x4 with 6 ft bed a new larger tank costs 1500 bucks this small addition is the same when comparing gallons and only cost me maybe 300 at most ..
    Sent from my SM-N950U using Tapatalk
    4,224
    Default Re: Fuel tank mod/addon
    Quote Originally Posted by anomily88 View Post
    While anything is possible, this sounds like a bad idea to me. The possibility of unseen leaks that could start a fire or explosion is a chance I wouldn't take. Also, in the event of an accident or rollover, the danger is amplified for you and your passengers. The cost may only be $300 but it could cost you your life as well. Good luck.
  3. Thanks anomily88 "Thanks for this post"
    01-18-19
    They have special valves made for this called roll over valve but they all say for diesel fuel only I am not sure why besides the combustible risk
    4,224
    In my opinion, just carrying 20 gallons in the bed is dangerous. If I needed more range that bad, I would spring for the larger tank.
  6. Thanks anomily88 "Thanks for this post"
  7. #5
    01-18-19
    Quote Originally Posted by tonyspin View Post
    The larger tank is great just I have affordability issues right now for that it costs 1500
  8. #6
    01-18-19
    I think I am going to make a custom tank to go where my spare tire used to be at and I will make a spout so I can fill it up through my truck bed i can fit a 30 inch tire in that spot so at least I can make a 25 gallon tank fit their or bigger
  9. #7
    4,224
    And how do you plan to transfer to the main tank?
  10. Thanks anomily88 "Thanks for this post"
  11. #8
    01-18-19
    I will buy and use the same kit that u would buy for a diesel transfer tank I will have a small pump hooked up to a switch and it will be hooked up to the hose that connects the tank to the fill up tube on the side of my truck
  12. #9
    4,224
    Good luck with this mod. Please post pictures when you can.
  13. Thanks anomily88 "Thanks for this post"
  14. #10
    12,018
    186
    Check with the tank companys. See what they recommend. I’m putting a 46 gal direct replacement tank in the next couple of weeks. I’ll let you know haw that goes.
  15. Thanks anomily88 "Thanks for this post"
  1. 2011 5.7 DC fuel tank size
    By dclements0 in forum 2007/2013 Tundra Issue Discussion
    Last Post: 06-04-2016, 01:15 PM
  2. [Want To Buy] 46 Gal Replacement Fuel Tank
    By Hoss1214 in forum Vehicle Classifieds
    Last Post: 01-05-2016, 03:55 PM
  3. 38 gal. fuel tank
    By mrores in forum Ask The Professor!
    Last Post: 10-18-2015, 10:56 PM
  4. F-150's Plastic Underbody Fuel Tank Shield Spells Trouble!
    Last Post: 06-26-2013, 07:18 AM
  5. Aftermarket fuel tank.
    By crzy2bealive in forum Misc. Accessories
    Last Post: 12-08-2010, 07:31 PM
