Results 1 to 4 of 4
Thread: 2007 Tundra 5.7 2WD, 204,000 miles Code P0977
    12-27-18
    Default 2007 Tundra 5.7 2WD, 204,000 miles Code P0977
    My Tundra did a "stumble" which felt like a missed shift, check engine light came on, VSC flashing and traction symbol on steady. CAN OBDII showed code P0977 and reads "Shift Solenoid B, Control Circuit High. From other posts I believe it to be shift solenoid valve "S2" is causing the fault. If I reset the code it will come back on but at different times, meaning sometimes after driving 10 miles and sometimes shortly after the reset. I have been driving with the shift lever in S and manually shifting through the gears, which has not resulted in a fault being thrown. I'm taking the truck to a transmission shop and hope to get them to do a full oil flush of the trans fluid (I paid for a $250 flush by Toyota at ~125K miles but uncertain if they actually replaced all the trans fluid). Just wondering what other's have experienced. Maybe it makes sense to pay transmission shop to drop pan and do a resistance check of the S2 solenoid?? Anyway, just looking for what others have experienced, the level of troubleshooting, end results, useful web sites to review, etc. The truck has been the best vehicle I have ever owned. Thanks in advance.
    4,232
    Default Re: 2007 Tundra 5.7 2WD, 204,000 miles Code P0977
    It is worth a try to do a flush. Why do you think the Toyota dealer didn't change your fluid? Where are you located? If you are in the NYC area my dealer will do a flush for you.
    01-10-19
    Can you not ask them to tell you what they did to the vehicle exactly?
    4,232
    Please let us know if you resolved this issue.
  1. [Want To Sell] FS: 2007 Tundra Limited w/ 153,000 miles $12,500 or B/O
    By HopDevil814 in forum Vehicle Classifieds
    Last Post: 12-03-2018, 01:58 AM
  2. 2007 Toyota Tundra with 666,803 Miles on It!
    Last Post: 10-05-2012, 08:36 PM
