G-Tek Fab SABM
Results 1 to 3 of 3
Thread: Headlight out
    blackdemon's Avatar
    11-20-08
    NorCal
    766
    $21544
    21
    Default Headlight out
    So my truck is showing her age. I've lost a headlight. The turn signal, highbeam all work, but the low beam light is out and the bulb is not the culprit nor is the fuse. I've checked, twice. So I'm just getting started troubleshooting since I just discovered it this morning, but due to work and other circumstances I haven't gotten around to it.
    Any one else had similar issues??
    Thread Author
    (. Y .) my anti-drug
    Mods
    -Front License plate removed
    -FJ Cruiser Running Boards
    -White Turn signals
    -Truck Covers USA Roll Cover
    -Laufenn XFit AT 275/65-R18
    -TRD anti-squat bar
    - Optima Yellow top
    Up coming Mods
    -VLED interior lights
    4,211
    80
    Default Re: Headlight out
    Check for corrosion on the bulb socket or connector. Could also be a bad ground. Do you have power at the connector?
    blackdemon's Avatar
    11-20-08
    NorCal
    766
    $21544
    21
    Sorry for the delay on the update. So I worked on it yesterday morning, but it rained me out mainly so I didn't take any pictures referencing the damage. I had some frayed wires inside the plastic protection by the fuse box to the headlight. I screwed myself by plugging in the right light bulb to test if it was the bulb one more time and it blew it out. I bought some new fuses, bulbs and an old socket plug from a junk yard Tundra I picked up awhile back, even though no fuses were blown I changed them out, and I soldered and shrinkwrapped the new wires and socket and both are working fine now. Both grounding points by the headlights were also loose, so before I plugged everything back in I tightened everything down I double checked everything else, but so far so good.
    Thread Author
    Mods
    -White Turn signals
    -TRD anti-squat bar
    - Optima Yellow top
    Up coming Mods
  1. Headlight help
    By Skibo in forum 2014+ Toyota Tundra/3rd Generation Discussion
    Last Post: 01-05-2015, 08:12 PM
  2. Headlight Adjust
    By raven41951 in forum Ask The Professor!
    Last Post: 12-31-2014, 05:25 AM
  3. Toyota Tundra Headlight Modifications Headlight Revolution
    Last Post: 05-16-2013, 05:11 AM
  4. Headlight LED strips
    By Pitbull Joe in forum Headlights/Tail Lights/Third Brake Lights/HID & LED's
    Last Post: 06-04-2012, 07:39 AM
  5. Headlight Question
    By Big_C in forum Headlights/Tail Lights/Third Brake Lights/HID & LED's
    Last Post: 12-30-2011, 09:17 AM
