Below Header GoPro
Results 1 to 12 of 13
Thread: 08 Tundra having Electrical Issues
    Rookie mikecabrera's Avatar
    10-11-17
    7
    Default 08 Tundra having Electrical Issues
    I have a 2008 Toyota Tundra CrewMax 4x4 116K miles. Lately I've been having electrical issues that start with the dash totally losing power and engine cutting off. Had to tow it to the dealer only to pass all checks and start no problem there. I changed the alternator and again losing power to the dash cluster, alternator constantly moves from 1/2 to 1/3. The only thing that lights up on the dash is the "P" transmission gear position, all other lights off. All other electronics work, radio, lights, and windows. The truck will not start when dash loses power. And if it starts, no telling when it will die.
    Any help would be appreciated.
    Thanks,
    Mike
    4,191
    79
    Default Re: 08 Tundra having Electrical Issues
    Quote Originally Posted by mikecabrera View Post
    What does that mean?
    10-11-17
    7
    . This the alternator gage operating at 1/2 mark 14 volts.
    4,191
    79
    14 volts is normal when the engine is running. Have you had this truck since new? Has it ever been flooded? I would remove the dash cluster and check for corrosion on all the connections. Also check body and frame grounds for corrosion. If you find corrosion on any connectors or grounds, clean them well and coat in di-electric grease. Please let us know what you find.
    755
    20
    Have you checked the battery?? My battery died last year and was doing something similar where my alternator gauge would swing from a 1/3 to a 1/2. Check fuses if you haven't already. Mind the service light and the 2 TPMS sensors are dead.
    10-11-17
    7
    Had the truck new since 07' it's my hunting truck. It does see snow, mud and occasional river crossings. I drive it about once a week, generally parked the rest of the time. So it make sense ground contacts possibly rusting up. I'll check that this weekend.
    4,191
    79
    Quote Originally Posted by blackdemon View Post
    The dealer will check the condition of the battery when a vehicle comes in for electrical problems.
    755
    20
    I went through quite a bit of batteries going through the dealership from 08-10
    10-11-17
    7
    Cleaned out the ground contacts and battery posts. Now it's completely dead. Started once and died. Bought new battery, still no go.
  10. #10
    10-11-17
    7
    Bad Ignition 30A fuse in engine cab. All good now.
  11. #11
    4,191
    79
    Wow, glad to hear you finally got it resolved!
  12. #12
    10-11-17
    7
    I figured out the problem, fuses build up dust over time, specially if you go off road. I'm cleaning out the fuse box after I remove all fuses. To remove any caked on dust build up.
  1. Anyone Else have tundra leaf spring issues ?
    By 07TundraTrd in forum 2007/2013 Tundra Issue Discussion
    Last Post: 06-12-2018, 05:57 AM
  2. 08 tundra battery issues
    By Yotayes in forum Ask The Professor!
    Last Post: 04-18-2016, 12:25 PM
  3. 2005 TRD Tundra - 4WD issues - troubleshooting
    By calumtundra in forum Ask The Professor!
    Last Post: 01-20-2015, 08:20 PM
  4. 2012 Tundra issues
    By Allwelding in forum NEW MEMBER INTRODUCTIONS, Site Rules & Info
    Last Post: 04-07-2013, 07:57 PM
  5. Couple 2010 Tundra 5.7 issues
    By Joshc8503 in forum 2007/2013 Tundra Issue Discussion
    Last Post: 07-27-2012, 07:08 PM
