Below Header GoPro
Thread: 2003 Tundra Limited, 2wd, Front Suspension Issue
    09-21-17
    Default 2003 Tundra Limited, 2wd, Front Suspension Issue
    I have a 2003, 2wd extended cab Tundra with a V8,178,000miles, that makes a popping noise in the front right whenever I make a right turn onto a driveway that has an incline to it. I have had the front shocks replaced as well as the sway bar and it still makes that noise. New shocks are coil over Bilstein sway bar was new Toyota part. Any suggestions will be appreciated.
    4,135
    77
    Default Re: 2003 Tundra Limited, 2wd, Front Suspension Issue
    Why not go to the dealer and have them diagnose the problem? Dealers would normally charge 1 hour labor to diagnose. You have already spent more on parts that you probably didn't need.
    09-06-17
    Orange County, CA
    4
    +1 to tonyspin. With that being said, I had a similar issue on a 2006 BMW AWD a few years ago which ended up being two shorn-off motor mounts.
  4. Thanks Dez "Thanks for this post"
  1. Replacement front suspension advice
    By Rpugh in forum 2000/2006 Tundra Maintenance/Repair/Specs/Warranty Discussion
    Last Post: 11-12-2015, 01:12 PM
  2. N-fab front bumper with light bar fit issue
    By 13SoCalTundra in forum 2014+ DIY Guides and Mods
    Last Post: 04-05-2015, 08:06 AM
  3. Front DrawBar 4 spotting Trailer,how much weight will front suspension take 2011 2WD
    By mazolarry in forum Suspension DIY's/Mods/Installations
    Last Post: 07-19-2013, 07:18 AM
  4. Front Suspension Torque Specifications
    By mt pockets in forum Suspension DIY's/Mods/Installations
    Last Post: 02-05-2013, 07:22 AM
  5. Turbo tundra 2003.
    By NEW MEXICOS BEST in forum IF57 Race Group
    Last Post: 05-02-2012, 06:30 PM
