Shop at 4WheelParts.com and get FREE SHIPPING and 100% Price Matc
Thread: 09 ABS actuator incompatibility with ECU?
    05-06-17
    Northern Wisconsin
    2
    Default 09 ABS actuator incompatibility with ECU?
    2009 Tundra Rock Warrior, 5.7 4x4 Flex Fuel. Jumped in my truck the other day headed to work. While driving I noticed the 4 hi 4 low lights alternately blinking at me, I pulled over and checked everything out. The results are, no speedometer, all the idiot lights are on, no traction control or skid, no seatbelt ding and no 4 wheel drive. I took it to the dealer and there test results said I need a new ABS actuator. My ABS unit is getting all the signals in just fine but has no output at all. Instead of paying the $2100.00 the dealer wants for a new one, I got a couple used ones for 2 different very reputable on line salvage facilities. Both units where the correct part number for my truck and came with a 6 month warranty.
    The dealer tried to install both units and they both came back with a ECU incompatibility code. The only difference with the salvage units and my truck is mine is a flex fuel model and the salvage units are not. Could this small difference be the problem? Or is it more likely my ECU is bad too?[/SIZE][/SIZE]
    4,173
    78
    Default Re: 09 ABS actuator incompatibility with ECU?
    Try to get one from a Flex Fuel truck.
    05-06-17
    Northern Wisconsin
    2
    If I could find one I would
