Results 1 to 4 of 4
Thread: Has anyone tried removing/disabling the Stability Control system?
    fixnflip's Avatar
    02-22-17
    Atlanta
    2
    Default Has anyone tried removing/disabling the Stability Control system?
    I have an '05 double cab with Stability Control. Needs a master cylinder and brake booster due to a leak. Because of the ESC option, the parts are impossible to find except from a dealer....upwards of $1000 just for the cylinder.
    I'm wondering if I can just put a standard master back on it, and remove the ESC or plug the lines. Would this cause havoc with the computer?
    Hoping someone has experimented with this already. It's a 12 yr old work truck that only sees dry pavement, I don't need Stability Control anyway.
    Sent from my iPhone using Tapatalk
    25,203
    363
    Default Re: Has anyone tried removing/disabling the Stability Control system?
    Not sure about the 05 but I disabled mine on an 07 by disconnecting the censor connectors from the two front wheels.
    fixnflip's Avatar
    02-22-17
    Atlanta
    2
    Quote Originally Posted by Dez View Post
    Did you have issues with computer, or check engine light staying on? I want to take the system off IF it doesn't cause problems.
    25,203
    363
    The wheel sensors on the 2nd gen have to do with the abs and stability control so all I have are a couple dummy lights on but no issues with the computer at all. I've had it like this for 5 years.
  1. Removing fog lights (07+)
    By Cards186 in forum Headlights/Tail Lights/Third Brake Lights/HID & LED's
    Last Post: 10-16-2014, 05:43 PM
  2. ICON 07-Up Tundra Billet Aluminum Upper Control Arm System
    By crzy2bealive in forum 4X4/Long Travel Suspensions/Lift Kits
    Last Post: 11-08-2011, 06:15 PM
  3. Vehicle Stability Control Pros and Cons
    Last Post: 07-07-2010, 06:30 AM
