Thanks Thanks:  5
Results 1 to 12 of 19
Thread: Tundra Stock Air Box Mod kits are still moving!
    25,280
    365
    Exclamation Tundra Stock Air Box Mod kits are still moving!
    G-Tek Fab SABM (Stock Air Box Mod) kits are still available!!
    Better gas mileage plus added performance at a fraction of the cost of an aftermarket CAI!
    Works great if you've lifted your truck and added bigger tires.
    This kit is designed for the 2007/2015+ Tundra 4.7 and 5.7 non supercharged/supercharged with stock and TRD intakes!
    DON'T FALL FOR CHEAP plastic KNOCKOFFS! The materials used on the G Tek Fabs are meant to be in motor compartments and will last forever.
    Not sure what the SABM? It's a Stock Air Box Modification Kit that was developed back in 2007 when I first had my truck lifted. I loved the power when I first drove it but after lifting it and adding 37" tires it lost its punch. I searched for a way to add a little power so the first thing I looked at was a possible modification to the stock intake.
    After the modification the first thing I noticed was added performance, then I realized I was getting better gas mileage! This modification allows the motor to run more efficient at the same time allowing it to gulp more air when you step on it.
    More bang than an aftermarket cold air intake at one third the price for sure!
    There have been so many positive results by members after doing this mod I decided to put together a kit.
    Some great results are coming from the super charger guys! 8 to 10 HP gains!
    Here's what the kit includes...
    * Two 3" 6063 aluminum flange pieces one with a foam gasket attached.
    * Two 4"x3" aluminum flange rings one with a foam gasket attached.
    * One 5" length of foam seal for the outside of the air box base.
    * One 7" length of foam seal for the inside of the air box base.
    * One 4 ply silicone intake tube in black, red, or blue.
    * Two stainless steel 3-1/2" hose clamps.
    * Complete set of illustrated step by step instructions performed by a Toyota Tech on his own Tundra.
    * G-TEK Fab, TRDShop.com and Tundra Geeks sticker pack.
    We suggest using K & N replacement Filter 33-2387 for the 2007/2013 5.7's with this kit for best fitment and the K & N replacement filter 33-5017 for the 2014/2015+
    For order and price info contact Dez here>>> PM Dez
    If you're viewing from the outside and you don't feel like registering just order or request info through our "contact us" link at the bottom of every page.
    ...or click here >>> http://tundrageeks.com/forum/sendmessage.php
    You can also find them at www.TRDShop.com
    watsonc3's Avatar
    11-05-15
    South Carolina
    9
    Default Re: Tundra Stock Air Box Mod kits are still moving!
    Dez, I've been researching CAI's and am thinking about giving your mod a go and see how I like it. The question I have, is your only dyno numbers just for the addition of you SABM or the SABM and a high flow filter? I have a 2014 CrewMax 1794 Edition with 5.7l Flex engine, and the only change as far as performance so far is a Gibson Performance Dual Exhaust.
    25,280
    365
    Sorry, I'm a little unclear about your question?
    watsonc3's Avatar
    11-05-15
    South Carolina
    9
    Quote Originally Posted by Dez View Post
    The dyno numbers you have were for a 5.7l that was supercharged correct? Did the person have a stock airbox with stock filter dyno runs and then change to your SABM and do a dyno run? Or did they change the Air filter from stock to a higher flow filter as well? I hope this question is arranged better as to make more sense.
    25,280
    365
    Lol got it. The Dyno was done on a certified Toyota techs 5.7 with a stock filter.
    watsonc3's Avatar
    11-05-15
    South Carolina
    9
    Roger that, do we still pm you about ordering them?
    25,280
    365
    Yes sir.
    ...or if you want you can order through www.TRDShop.com
    25,280
    365
    Still moving and moving fast!
    Just shoot me a pm if you're interested.
    08-12-16
    How do I buy g-tell kit ?
  10. #10
    12,011
    185
  11. Thanks Dez, TRDJoe "Thanks for this post"
  12. #11
    TG Vendor
    TRDJoe's Avatar
    04-15-09
    MS
    1,104
    $67285
    29
    Yep, we have them in stock. Usually ships same or next business day.
    TRD | Magnuson Superchargers | Bilstein | G-Tek Fab | ReadyLIFT | WeatherTech
    I sell OEM, TRD and Aftermarket parts and accessories.
    PM me here, e-mail us here or complete our contact form.
    2016 Tundra CrewMax TRD Pro
    TRD Intake | LED DRL/Fog Light Upgrade | Predator Pro Steps | Corsa Exhaust
    BFG A/TKO2 285/65R18 | OEM Audio+ | Camlocker | DIY Auto Headlights
    2009 Tundra D-Cab TRD Sport
    Lowered, supercharged and SOLD
  13. #12
    12,011
    185
    Joe will take care of you for all your Toyota needs
    If I had more money he could retire.
  14. Thanks bama1302 "Thanks for this post"
  1. 07+ Tundra McGaughy's Lowering Kits
    By Dez in forum Lowering Kits
    Last Post: 04-25-2017, 03:56 PM
  2. [Want To Sell] -1st Gen Tundra Leather Kits-
    By NotABusiness in forum Classified Section
    Last Post: 05-09-2011, 06:18 PM
  3. 2nd Gen. Tundra Pirana Body Kits
    By crzy2bealive in forum Body Kits/Air Dams/Spoilers
    Last Post: 04-04-2010, 07:26 AM
