Results 1 to 7 of 7
Thread: 2004 Toyota Tundra Access Cab Courtesy Light
    01-17-16
    Default 2004 Toyota Tundra Access Cab Courtesy Light
    In my 2004 Toyota Tundra SR5 Access Cab 4X4 V8 there is an oval shaped blank (formally called a Side Trim Stopper - part # 62695-34010-E1) in each of the rear doors (as shown in the picture - see inside the yellow box).
    When I pulled the door panel off, I found an electrical connector just under this blank stopper.
    My guess is that a courtesy light could go in this oval shaped spot.
    Has anyone else actually figured out why the stopper is there or if a courtesy light can be installed?
    Is there an actual Toyota OEM part that fits?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    bsavoir's Avatar
    12-26-14
    Twentynine Palms, CA
    336
    $7075
    8
    Default Re: 2004 Toyota Tundra Access Cab Courtesy Light
    I looked on TRDshop.com and I didn't see any parts listed for area of concern.
    http://stores.revolutionparts.com/tr...ber=48141ac010
    What type of power does the wires provide? Power only when key is in ACC/RUN position or when the door opens. Do you have a multi meter or any way of check for power.
    01-17-16
    Quote Originally Posted by bsavoir View Post
    I just checked and if there was a bulb installed, it would perform exactly as the courtesy light on the front door...so it seems as if the four door courtesy lights are all wired together.
    01-17-16
    Here is another photo of the oval-shaped blank on the rear access door.
    I'm really hoping that there is a magical OEM courtesy light that I can install there.
    12,013
    185
    PM trd shop
    If it exists he should be able to get it.
    I've ordered trim pieces from joe before. Good guy good place
    12,013
    185
    10-20-17
    That's a great shop indeed. Only had great experiences there.
  1. 2004 Toyota Tundra Lift
    By Hstraw in forum 2000/2006 Tundra Off Road
    Last Post: 01-09-2016, 04:27 PM
  2. BD Testing Round 2 courtesy of Toyota Tunerz
    By Supercharged in forum IF57 Race Group
    Last Post: 11-28-2013, 08:04 AM
  3. 2004 Tundra 3rd brake light
    By Hstraw in forum 2000/2006 DIY Guides & Mods
    Last Post: 06-15-2012, 04:38 PM
  4. 2000-2006 Toyota Tundra Access Cab 2pc Floor Mats
    By Tundras on Ebay! in forum Ebay Tundra Buys!
    Last Post: 03-21-2011, 04:50 PM
  5. Toyota tundra 2000-2004 lh headlight lamp
    Last Post: 03-13-2011, 06:09 AM
