Results 1 to 5 of 5
Thread: Traction control is going crazy after moving up in tire size
    07-17-15
    Default Traction control is going crazy after moving up in tire size
    Shop at 4Wheelparts.com for 20% off sitewide and FREE SHIPPING
    2013
    Sent from my XT1254 using Tapatalk
    25,324
    366
    Default Re: Traction control is going crazy after moving up in tire size
    Take her to the dealer for a zero point calibration.
    ^^^What he said!
    After installing a lift, or changing tire size, the characteristics of the G & Yaw Rate sensor can be affected, causing traction control to activate sporadically. Get it calibrated and you should be good to go!
  4. Thanks Dez "Thanks for this post"
    Rookie Bud Tugley's Avatar
    07-09-15
    Shadow
    42
    Let us know how it turns out. Mine came with the 20" rims and low profile tires and was thinking about going to a taller tire on same rim.
    02-05-18
    Santa Clara, CA
    22
    Nice insights though. I'm looking for a new set of tires to go with the changes I made on the lift.
  1. what tire size am i looking for????
    By 08tundra in forum Wheel & Tire Fitment Questions & Info
    Last Post: 08-17-2013, 02:50 PM
  2. what tire size?? please help!
    By 08bluestreak in forum Wheels, Tires & Brakes
    Last Post: 05-22-2012, 05:28 PM
  3. Traction Control kicking in...
    By Kracken in forum 2007/2013 Tundra Issue Discussion
    Last Post: 06-10-2011, 04:21 PM
  4. Tundra Traction Control Comparison Videos A Tale of Two Agendas
    Last Post: 05-20-2011, 12:38 PM
