TRDShop
Thanks Thanks:  11
Page 4 of 4 FirstFirst ... 234
Results 37 to 45 of 45
Thread: 07, 5.7, dc 2wd transmission issues
  1. #37
    4,232
    81
    Default Re: 07, 5.7, dc 2wd transmission issues
    Quote Originally Posted by Manzoni View Post
    Hope someone sees this post! So recently had some rats tear apart my knock sensor wires says the dealer. I took it to them saying i have a P2147 code. They now found a p0751 code, toyota dealer trying to sell me used tranny because they say its not worth fixing. Is this true? Or should i just open it up and change the bad sensors noted above “A” and “D”
    Truck wont shift out of 3 rd gear 4 low light on, check engine light on, traction control light on.
    What the hecks goin on!
    What year is your truck? 2WD or 4WD? How many miles?
  2. Thanks Manzoni "Thanks for this post"
  3. #38
    25,324
    366
    I had a desert kangaroo rat chew through both knock sensor wires on my 2000 Tundra which sit on top of the block. I talked to the dealer and they quoted me some crazy cost to replace the entire harness. I said forget that and removed the entire intake manifold to expose the knock sensors. They were chewed right down to the resin on top of each sensor so I chipped away the resin to expose enough wire so I could solder the chewed off wire back to the sensor. All was good.
  4. Thanks Manzoni "Thanks for this post"
  5. #39
    25,324
    366
    P0751 is the shift solenoid and P2147 is fuel injector group A so it sounds like the rats chewed through a few wires. I would find the damage then see if you can match up the wires and solder them back together.
    By the way, knock sensors rarely go bad. Back away from that dealer!!
  6. Thanks Manzoni "Thanks for this post"
  7. #40
    25,324
    366
    Skim through this thread on tundra solutions this guys got some different codes but it will show you where the knock sensors are. I suspect your rat or rats feasted on the harness under the intake manifold.
    https://www.tundrasolutions.com/foru...7l-code-p033d/
  8. Thanks Manzoni "Thanks for this post"
  9. #41
    02-18-19
    4
    Thanks for reply guys. The knock sensor wires are now fixed.
    Truck turned back on like normal drove down the road all the lights came back on
    2007 toyota tundra single cab 5.7 4x4
    180k for the miles
    Says i have a p2714 and p0751. Both are under my understanding transmission solenoid codes. Wont shift out of 3 rd gear with 4 low check engine light and traction control lights still on. Dealer seems to think trans is not worth fixing. I want to open it up replace bad solenoids and go from there. What do you guys think
  10. #42
    02-18-19
    4
    Ive been on that forum link as well and have gotten some great feedback just wanted to extend my feelers even more
  11. #43
    25,324
    366
    So all these issues came up at the same time originally? How much googling have you done? Maybe the rats set up camp at a few locations.
  12. #44
    02-18-19
    4
    Yup! All original problems with the addition to the solenoid A
    Ton of googling and forum posts with pretty good results
    Wish i could figure out how to up load the paper from dealer saying what they did
  13. Thanks Dez "Thanks for this post"
  14. #45
    25,324
    366
    If they all popped up at the same time well then i smell a rat! PM TRDJoe here on the site and see if he can help out with maybe a wire diagram of the shift solenoid.
  1. Heater & AC Issues
    By Tundrachick82 in forum 2007/2013 Tundra Issue Discussion
    Last Post: 08-24-2012, 11:07 AM
  2. Tapatalk issues
    By DonnyT in forum Technology Center
    Last Post: 11-15-2011, 09:00 PM
  3. Bluetooth issues
    By TurboHeloDriver in forum Tundra Electronics/Window Tinting/Vinyl Graphics
    Last Post: 09-11-2011, 03:16 PM
  4. Having issues with my brakes
    By 07TundraTrd in forum 2007/2013 Tundra Issue Discussion
    Last Post: 02-20-2011, 09:52 AM
