Thanks Thanks:  14
Page 11 of 11 FirstFirst ... 91011
Results 121 to 132 of 132
Thread: Brian's 2014 Tundra SR5 DC Build
  1. #121
    bsavoir's Avatar
    12-26-14
    Twentynine Palms, CA
    337
    $7075
    9
    Default Re: Brian's 2014 Tundra SR5 DC Build
    Installed TRD pedal covers. Found them on Ebay.
    Sent from my LG-H811 using Tapatalk
  2. #122
    bsavoir's Avatar
    12-26-14
    337
    $7075
    9
    Installed a Fortin evo one remote starter w/ T harness as I'll finally will need it for this winter in Upstate New York. This thing was very easy to install, 2 cuts, 4 taps, snd put the ignition wire in between the module's and T-harness 6-pin pink wire. I would highly recommend this over the OEM if your on a budget. The engine also stays started when the door opens as i have read that's an issue with OEM remote starter.
    Best of all you can keep your original remote, press the lock 3x or Lock, Unlock, Lock to start/kill. The only issue I have is getting my crimestopper long range RF kit to work but I'm determined and I'm sure I'll figure it out later not a necessity as if yet.
    Sent from my SM-G930T using Tapatalk
  3. #123
    4,287
    82
    How much was that kit?
  4. #124
    bsavoir's Avatar
    12-26-14
    337
    $7075
    9
    150.00 from Amazon, had to buy the fortin flash link updater which costed 42.00. The flash link allows you to update the bypass module whenever and change your own settings. It even had the instructions inside the box and they were 100% accurate. Most kits that are sold by shops on there have everything already set up so it's just plug n play.
  5. #125
    bsavoir's Avatar
    12-26-14
    337
    $7075
    9
    Finally got rid of my bedliner insert and went with linex (Premium) and couldn't be happier, looks way better and no longer have to smell hot plastic coming in my windows or having it raise up when the plastic gets hot. I also had my grille sprayed with the premium spray. It turned out better than I had expected. I got sick of painting it everytime I had debris from the road and causing chips and scratches.
    Sent from my SM-N950U using Tapatalk
  6. #126
    4,287
    82
    Looks good!!
  7. #127
    bsavoir's Avatar
    12-26-14
    337
    $7075
    9
    I've decided to get an air locker, 4.88 gear and a 3-5in lift as my next major mod. I received my under-the-hood compressor mount and an ARB high output on-board compressor. Pics to follow.
  8. #128
    bsavoir's Avatar
    12-26-14
    337
    $7075
    9
    ARB Compressor and a custom made compressor mount.
    Thread Author
  9. #129
    Rookie Unionthug's Avatar
    04-07-19
    6
    Quote Originally Posted by bsavoir View Post
    I got my new headlights installed and billet grill bolt on installed. Next is the pop lock install for the tail gate, see how that goes, then debadge and paint black, same for the chrome around the grill and maybe even the grill. And the silver or greyish panels inside also will be painted?
    Attachment 6085
    Attachment 6087Attachment 6086
    Hi, you mind sharing where you got your LED,s and how much trouble was the install?
  10. #130
    bsavoir's Avatar
    12-26-14
    337
    $7075
    9
    My truck will no longer be with me, tomorrow I am for sure they will declare it totalled. Today me and my two young girls were in an accident, everyone made it out fine no injuries. All the airbags except the passenger deployed. Considering the airbags are expensive to replace. I am optimistic but money is the deciding factor here. But currently have plans to get another tundra if the price is right, or a Tacoma TRD Sprt 4x4, or forerunner.
    Sent from my SM-N960U using Tapatalk
  11. #131
    4,287
    82
    Wow, thank God you and your girls are OK. The Tundra's final act of service to you was to protect you and your family!!!
  12. #132
    Jack Ass JPNCA's Avatar
    11-19-08
    The state of confusion
    12,032
    $152727
    186
    Wow
    Glad your family is ok.
  1. Toyota Tundra 2014 Build Requests
    Last Post: 05-13-2014, 04:51 PM
  2. 2014 build
    By CGS in forum 2014+ Tundra Build Logs
    Last Post: 05-12-2014, 12:47 PM
  3. 2014 Tundra Build Logs...
    By Dez in forum 2014+ Tundra Build Logs
    Last Post: 03-20-2014, 03:09 PM
  4. 2014 Toyota Tundra Crewmax Limited Build Log
    By Elk Terd in forum 2014+ Tundra Build Logs
    Last Post: 01-28-2014, 07:19 AM
  5. DIY 2014 Tundra Now Available Build Your Own New Truck
    Last Post: 04-03-2013, 06:30 PM
